Cracked rear wheel castings
Ron
03-06-2000 14:39:51
Saw a model 50 tractor on Saturday that had rear wheel castings cracked outward from the rear axles. Two cracks approximately opposite from each other and almost all the way out to the rims. Have never seen that before. Anyone else ever see that? What would cause that? Maybe a lot of sharp turns using the brakes to assist?
OCB
03-07-2000 19:17:33
 Re: Cracked rear wheel castings in reply to Ron, 03-06-2000 14:39:51
A previous Post confirmed that the early 50's had a problem which caused a redesign about 1954. I have never heard of a fix to repair or stop the crack so I'm watching mine.
Doug
03-06-2000 18:34:32
We have a 4320 that has had a cracked wheel casting for 10 years. It just suddenly appeared and hasn't gotten any larger. It also has 4 weights on each side.
bigbadjohn
03-06-2000 17:47:25
I have seen wheel huds break and crack a wheel on a 4430. The same thing could happen on a 50. Could be caused by a loose hub.
