4520 JD hyds, pickup screen.
Alvin n Ms.
11-04-2003 06:50:55
Need to find where the pickup screen is located on 4520. I have got the plug out just to the rear of the two oil filters on the left side. Thanks,Al
JimKS
11-04-2003 11:12:08
 Re: 4520 JD hyds, pickup screen. in reply to Alvin n Ms., 11-04-2003 06:50:55
yep, like David said- it's behind that plug that you have out. Reach back in there with two fingers, you'll have to twist it around a bit but they usually come out easy enough. That screen is open on both ends, so it may be different from what you're expecting.
bill
11-04-2003 07:19:18
If I remember right, it should be behind that large suction pipe coming out on the filter side of tractor, Bill
david val
11-04-2003 07:32:59
 Re: Re: 4520 JD hyds, pickup screen. in reply to bill, 11-04-2003 07:19:18
that's probably it. try to pull the screen with two fingers. if it's stuck, a large snap ring pliers may help(make sure you use the pliers at the pipe end of the screen and not the screen itself).
david
Alvin n Ms.
11-04-2003 15:06:59
 Re: Re: Re: 4520 JD hyds, pickup screen. in reply to david val, 11-04-2003 07:32:59
Thanks for the info. I will try to get it going real soon. Best wishes, Al
