Pto shaft that points to the front?
jw
03-05-2000 16:32:16
what is the shaft that comes out of the front of the rear end for? it looks like a pto shaft Sorry this is on a 4010
MrG
03-06-2000 08:26:43
 Re: pto shaft that points to the front? in reply to jw, 03-05-2000 16:32:16
Cornpicker
Doug
03-05-2000 19:16:36
Side mounted sickle bar mower. Pulley mounts to the PTO shaft and belts run to the mower. Thats what I have seen around here. (East Central Illinois)
STMTS
03-05-2000 18:10:34
In our part of the country the front PTO was used on 282-283 cotton strippers with baskets
Jarrod
03-05-2000 17:10:51
A belly mower or other things of that nature
Rhill
03-06-2000 07:03:21
 Re: Re: pto shaft that points to the front? in reply to Jarrod, 03-05-2000 17:10:51
Is this p.t.o. 540 or 1000 As they have 1000 rpm spline? Just curious.
Craig
03-09-2000 18:11:33
 Re: Re: Re: pto shaft that points to the front? in reply to Rhill, 03-06-2000 07:03:21
I don't know for sure but I think on the 3010 and 4010 tractors the RPM is either 540 OR 1000 depending on which PTO stub you install on the BACK of the tractor. On the 3020 and 4020 they changed the gear train inside and the front PTO runs ONLY at 1000 RPM not matter which PTO stub is on the back of the tractor.
bigbadjohn
03-06-2000 18:07:18
This is a 1000 rpm shaft.
