720 LP Standard
Tired farmer
11-03-2003 19:46:27
Dad and I have owned this tractor for most of it's life.This has been a good tractor till now.It's never went to the shop.Having trouble now getting it to run.It ran great ...then it started to go down hill till it won't pull itself.Replaced or repaired about everything I can think of.Regulator,Elec shutoff,cleaned carb and intake.Plugs, points and coil.Don't think I getting fire now.It's got good compression.Need some good advice....Or is it time to update to a newer tractor?Dad says trade,But I think he wants a 6 cylinder to play with.
OK-AL
11-04-2003 16:58:17
 Re: 720 LP Standard in reply to Tired farmer, 11-03-2003 19:46:27
Two things come to mind. One, there's a wire that runs from the starter to the coil. When you hit the starter pedal, it puts 12 volts directly to the coil, bypassing the resistor which gives the engine a hotter spark. Check this wire and make certain it's suppling 12 volts when the starter is spinning.
Two, make certain that the coil is getting 12 volts when the ignition switch is turned on. If not, then back up through the ignition circuit - resistor, switch, etc. Use a voltmeter. A lot of times a resistor will look good, but actually is open.
Now that i'm typing, here's a couple of other things. Air cleaner - Is the pipe to the air cleaner really clean? Mud daubbers love to build nests in those. Same thing with the exhaust. If they've built nests in the exhaust pipe, the back pressure will prevent the tractor from starting. Valves. Have you checked valve clearance? Incorrect valve adjustment will make it really hard to start.
Do the easy things first, make certain you're getting spark, then if it doesn't start, go through it step-by-step. You'll find it.
OK-AL
Tyler-MO
11-04-2003 02:41:40
Have you forgotten that little crucial part in the distributor..... the condenser----this could be why you have no spark or maybe a weak spark. I believe that it takes a hot ignition system to fire in a high compression situation. At any rate if you want to trade the tractor....I would think that you could easily sell the tractor.
Good luck Tyler-MO
