Drive Disc on a late model B (Can't get off)
Rooster in Tenn
11-03-2003 19:19:22
I was trying to get the drive disc off my b. But some one has broke a bolt off in the disc. How can I get the drive disc off? I had to heat the sliding drive disc all most red hot to get to turn a loose. This is the first time I have into a clutch on a JD. I have a shop manual. Any help would be helpful.
ChuckW
11-04-2003 06:22:41
 Re: Drive Disc on a late model B (Can't get off) in reply to Rooster in Tenn, 11-03-2003 19:19:22
if you think the disc is shot, you could use nickle rod and weld nuts to the facing, run your bolts in the nuts and make the pull...you need a good puller...I use a bar type with a large center screw...I know it will come off...takes some force.....
Tyler-MO
11-04-2003 02:48:51
Good luck! I had a late model B that I tried everything short of drilling around the splines and chipping it apart. Of course mine has the jack screw holes stripped out.
In your case I would try drilling out the broken bolt. A left handed drill bit might be a good way if available to you. Just be careful as those threads must be intact for this to work.
ALso, you could try a smaller gear splitter and clamp in behind the sliding gear lip (I would advise a gear splitter with the back side flat agains the drive disc as there isn't much room)*also you would need the kind of gear splitter that you can put threaded rod into and then use a puller to put pressure on the end of the crank.
I hope this gets your mind turning.
Tyler-MO
