G Ignition
Phillip
10-12-2003 19:49:46
How hard is it to put a turn key ignition on a G? and how much are they? THANKS!!
Clooney
10-13-2003 03:16:39
 Re: G Ignition in reply to Phillip , 10-12-2003 19:49:46
Phillip, not hard at all, or very difficult [depends on what you are trying to accomplish]�. What are you trying to accomplish with a "turn key ignition"?
~If just trying to have a safe way of locking your ignition in the off position all you will need is an ignition switch that the key can be removed in the off position. The type of switch required will depend on if you have a magneto or distributor in the tractor now. [post back & let us know if it has a mag or distributor].
~If you are wanting to install a distributor instead of a magneto that will require the correct Delco [or Wico] distributor, some 14 gage wire & an ignition switch�. If you don't have a battery in your G now that will make it a difficult installation.
~If you are wanting to put electric start on your G that will also be difficult.
~Post back & let us know what you are trying to accomplish by installing a "turn key ignition"?
[email protected]
John T
10-12-2003 20:29:46
Phillip, are you asking how hard is it to convert from a magneto ignition to a battery powered coil and distributor ignition, and if so a Delco Remy or a Wico????? Or on a mag its possible to install just a dash mounted kill switch if it has a mag now and thats all youre looking for.
If its a governor mount mag and you want to convert to a governor end driven Delco Remy battery powered coil/distributor ignition (assuming you have a battery tractor), all you need is the Delco distributor (installs where the mag was), a coil, a coil mounting bracket, and an on/off ignition switch. The coil needs to be either a 12 volt internally ballasted type or a 6 volt coil would have to have an added series ballast resistor.
TO CONVERT FROM A MAG TO A DELCO REMY DISTRIBUTOR
1) Buy a Delco Remy governor end mount distributor and mount it where the mag was.
2) Buy a 12 volt internally ballasted coil and mounting bracket (near the distributor).
3) Run a 14 gauge insulated wire from the load (non battery) side of the ammeter to the input of the dash mounted ignition switch.
4) Run a 14 gauge wire from the ignition switch output to the coils high (not to distributor) side.
5) Run a 14 gauge wire from the coils low (not to switch) side to the lil side terminal on the distributor.
6) The timing is similar to a mag. When the left cylinder is at TDC on its compression power stroke the points should be near open on high cam and the rotor tip in line with the tower going to the left plug. Then 180 later, the points open again and the right cylinder is at its power stroke TDC and this time the rotor tip will be pointign to the tower to the right plug. It will fit into the mags female drive cog slot just like the mag did. Gear reduction mags have to be in that slot right (not 180 out) to work, but non gear reduction drive mags like the Wico C and XH series or some distributors (Wico also made a battery powered distributor which looks like the XH series mag) can be in either way and still work if the wires are reversed. The TDC's I described and when the points open and to which tower the rotor tip is pointing to can insure youre installed correct, however, as the left fires and then 180 later the right on their power stroke TDC's.
7) You could rough in start time it by rotating the distributor to max retard (CW), slowly rotate the flywheel to bring the left piston up to TDC on its compresion power stroke, have it installed so the rotor tip is near the left plugs tower, and then (ignition on and left plug out so you can see or hear it fire) slowlyyyyy advance the timing (rotate CCW) until the left plug fires, and set it there. Then you could use a timign light and flywheel marks to see where shes runnign at at RPM.
Nuff said for now getting late. Post back or e mail [email protected] with any questions.
Good luck n God Bless
John T Nordhoff
