Head On 1955 70 Two Cylinder Diesel ?
Don C
11-03-2003 16:10:11
Hi folk's, first of all I want to thank all of you for your help on the previous post. The new $100.00 dollar question is--what are the casting number's for a 720 head? I'm thinking thats what I have on the ol-70 here. Also does this mean I would have the 720 injectors? I do have a parts manual for the 70 Diesel, so I will have to check that number to see if it is a 70 head. The next question is- if it is a 720 head, is that the head gasket I nead to ask for when I buy one? Thanks for all the help I will get from you guys. Don C.
Blksmok
11-03-2003 18:44:48
 Re: Head On 1955 70 Two Cylinder Diesel ? in reply to Don C, 11-03-2003 16:10:11
Don....I just bought the parts for a 70D head gasket replacement project. The gasket kit (AF3906R) was $94. Much cheaper than buying the head gasket ($45), lead washers ($3), exhaust manifold gaskets ($13) and all of the other paper gaskets and o-rings indidually. Later.
F-I-T
11-03-2003 17:49:14
Don:
Ok, here's what I think I know:
~~ 70D heads were AF 2461 R (assembly), subbed to F1958R or F3511R (casting number)
~~70D hd gasket: R21449R, subbed to F1959R or F3512R
~~720D Head: F3211R or F3511R
~~720D Head Gasket: F3212R, F3512R, both subbed to R21449R
So, I know they had problems with head cracking on the '70'D's, and it looks like they came out with a different head, F3211R for the 720. Then I think they still had problems, and subbed both the '70's and 720's to the even newer head F3511R. Regardless, they all use the same R 21449 R head gasket.
You said: Also does this mean I would have the 720 injectors?
~~Not necessarily. The 720 injectors will fit in the head, but are matched to the pumps. '70's had 10mm set ups, and the 720's used a 13 mm. I'm not sure if that was just the black dashes or after because they made a pump change, but that's the general drift.
So, it won't matter which head you have, they all require the same head gasket.
Frank
Gpower
11-04-2003 17:14:36
 Re: Re: Head On 1955 70 Two Cylinder Diesel ? in reply to F-I-T, 11-03-2003 17:49:14
F-I-T
Sounds as though you have the parts and heads all lined up good. The 720 Black Dash acquired the 13mm pumps at the change, as well as the black dash 820's getting 13mm pumps. The 820's went from a 5 hole to a 6 hole injector tip at this time as well, as well as some changes in the delivery valves. I cant remember if the early 720's had a 5 hole tip or not, I do know the 730's have 6 holes tips. Anyhow, just throwing that out there. Hows that web-site coming along??
Gpower
Blksmok
11-03-2003 18:48:53
Frank...when you reworked your 70D head did you replace the copper injector tubes and/or the o-rings? How do you remove the copper tubes w/o damaging them if you only wish to replace the seals???
F-I-T
11-03-2003 20:54:07
 Re: Re: Re: Head On 1955 70 Two Cylinder Diesel ? in reply to Blksmok, 11-03-2003 18:48:53
I did not remove them as they looked just fine. But, I have heard of guys threading a big tap into them and slide hammering them. That seemed to me that I was surely going to damage them, so I let well enough alone.
I may have been lucky.
Blksmok
11-04-2003 06:06:10
 Re: Re: Re: Re: Head On 1955 70 Two Cylinder Dies in reply to F-I-T, 11-03-2003 20:54:07
Frank....I think I will do the same. They appear to be in good shape and no leakage. The head I'm working on is the F1958R design, but I have a F3511R head (spare) and it does not have the copper sleeves nor the recessed circle for the machine screws and washers to hold the sleeves in the bore. Did they eliminate the sleeves on the 720 heads after s/n 7214899?? Thats what I decipher from the parts manuals i.e F1958R and F3211R heads had the sleeves and F3511R did not (??) Later.
