A JOHN DEERE
G VEST
02-27-2000 16:00:06
I have an A JD that has the oil filter bolt threads stripped and the part thats threaded up in the block in broke.how do i replace it ?
Robb
02-28-2000 19:39:35
 Re: A JOHN DEERE in reply to G VEST, 02-27-2000 16:00:06
I had the same thing with my 49 A, you have to drain the oil & remove the crankcase inspection cover the part you want to remove is called the oil filter housing head it is a seperate cast piece bolted on top of the filter housing remove the oil lines & bolts & it comes out the top becareful it is 2 pieces with springs in it try to pull it out intact so you see how everything goes
Kemper
02-27-2000 16:25:26
Is the stud broke off in the block?
