Pony motor
Kemper
02-27-2000 14:45:35
I have found 2 730's, one is pony start the other is elec start,i have never had anything with pony start and don't know much about them, I guess my question is elec start better? i will be using the tractor around the farm.
Bruce
02-28-2000 14:22:38
 Re: Pony motor in reply to Kemper, 02-27-2000 14:45:35
Kemper..... .Depends on where you live. If you have temperatures below zero in the winter months I've been told the pony engine is better. If not, the electric starting system is okay. Both are equally expensive to repair. The pony engine will nearly always start the diesel engine, you may just need to "motor" it longer in sub zero weather to build temperature before the compression release is disengaged.
Tim (UT)
02-28-2000 11:52:21
I've been told that as long as the pony is in working order, it's as good or better than the electric. Parts can still be gotten (direct from Deere) for the pony motors.
One good thing about pony motors is that you can crank and crank as much as you want without having to worry about burning up a starter.
I'm just getting into the pony motor stuff as I just got my JD 80 last week - we'll see how I feel in a few months.
