Can a JD 40 Loader fit a JD H???????????????
Josh Tanner
02-25-2000 16:18:19
Can a 40 loader fit a JD H? Just making sure before I look or buy one!
Thanks Josh
clooney
02-25-2000 17:13:10
 Re: Can a JD 40 Loader fit a JD H??????????????? in reply to Josh Tanner, 02-25-2000 16:18:19
Josh, I have seen a couple of homemade loaders on J.D. H's but its risky. The ft bolster on the J.D. "H" is pretty weak. If you were to lift much weight it would probably break the ft end off if you went through a hole or ditch.
