JD 2010 diesel crawler
Bob H
02-22-2000 18:43:22
I have a transmission leak in my crawler. There is a steady stream of fluid coming out of a tube that is around the staft that goes from the engine to the transmission. The fluid appears to be running out of the tube. That seems to me to be a bad seal which means I have to remove the engine to change a $5 part. Is it possible that the fluid is coming from somewhere else? When the engine is running the fluid is running onto the clutch plate and sprays all over everything including my face as I'm trying to see where it's coming from. That makes the diagnosis difficult. I was hoping someone would tell me it is a leaky hose that is cheap and easy to fix. Any help is greatly appreciated.
Steamer
02-23-2000 09:39:21
 Re: JD 2010 diesel crawler in reply to Bob H, 02-22-2000 18:43:22
I fear that you are on the right track (pun unintended) as to where the leak is coming from. I've not had a 2020C, but have had other models, and have had two input shaft seals go out. The oil spray off of the clutch sounds all too familiar.....
