JD B rod
Gary
02-22-2000 17:46:00
How picky do you have to be on babbited rods, One of mine has a small chip out of the center of it on the rod side. But the rest of it looks good. Should i replace it?
clooney
02-22-2000 18:00:53
 Re: JD B rod in reply to Gary, 02-22-2000 17:46:00
Gary, if the chip is in the babbit & not on the crank it won't be a problem, just make sure it dosn't have a raised lip around it. A lot of bearings have holes drilled or a channel cut in them for oiling.
Gary
02-22-2000 19:30:24
 Re: Re: JD B rod in reply to clooney, 02-22-2000 18:00:53
Thanks for the info on the rod.
