Adding oil to John Deere M
Scott in SC
11-03-2003 05:51:17
Just bought a model M. Has had recent head work.When I add oil, it takes it very slowly.Will overflow out of the filler spout if not careful.What gives????Thanks in advance, Scott
Mike M
11-03-2003 13:01:43
 Re: Adding oil to John Deere M in reply to Scott in SC, 11-03-2003 05:51:17
All you need to do is to lift up the dipstick or remove while you fill it up,this lets the air out when you pour in. Works on LA's too.
Wayne in Tn.
11-03-2003 06:30:29
Scott, that is normal, just give it time. If you will look down in the tube, you will see a baffle in there. I only lets a small amount flow through. I guess this baffle helps to keep the engine from blowing oil back out.
