420 Power Steering?
Dave B
11-03-2003 05:51:15
I'm looking at a 420 to purchase but don't much about them. Was wondering if power steering was an option on this tractor. And if it was, is adding on an option? Any info would be appreciated.
Dave B
11-03-2003 09:44:56
 Re: 420 Power Steering? in reply to Dave B, 11-03-2003 05:51:15
Ser. # is 89796 which would make it a '56 model.
Year Starting Serial Number - Model 420
1956 80001 1957 107813 1958 127782
Henry J
11-03-2003 15:26:41
 Re: Re: 420 Power Steering? in reply to Dave B, 11-03-2003 09:44:56
Dave
Looking through my reference it appears that you have to go up to a 58 to get power steering in all the models. However reference is made to power steering being made available in the Utility and Special Utility prior to 58.
If I was looking for one 420 again to keep, I would not change what I would look for. It would be a 5 speed with live pto and power steering.
I don't think the 5 speed came out until the first green and yellow model in 57 at which time the live pto was made an option with the 5 speed tranny.
After reading some more it appears that the 420U was available with power steering in 56. That would be an all green model.
Henry J
11-03-2003 09:32:32
Dave
You did not say the year and sn you are looking at. In mid to late 58 JD started putting on the rack and pinion unit with a separate pump that ran off of the fan belt (same as 430, I think). It is nice to put the palm of your hand on the steering wheel and steer.
Dan
11-03-2003 06:36:50
I would echo the post below. I have a 430 U I inherited from an uncle and it has a #35 loader. Hard to steer. I looked into the same thing but when looking at parts books there is an awful lot of stuff to change to Power Steering. It seems like the minority of these that had PS so not easy to find a donor. I think you could put one of the Charlyn units that goes in the steering shaft but it puts lots of stress on the steering gears. My 430 steers great without the loader and it goes on and off pretty easy so I remove it during the summer when using the tractor for other stuff and put it on in winter to feed.
Wayne in Tn.
11-03-2003 06:27:40
Dave, the 420-430 was available from the factory with power steering. There were 2 or 3 types available over the years. If it don't have it now, I would say it will be hard to find all the parts to add it on. It even takes a different light bracket on the right side. You probably would need a whole donor tractor in order to have all the parts.
Ray
11-03-2003 19:21:32
 Re: Re: 420 Power Steering? in reply to Wayne in Tn., 11-03-2003 06:27:40
I've seen a couple 430's lately with the old
diverter valve PS,thought that was only on the
early tractors.I saw a 430 T slant steer with
it also the other day.Now I'm really confused.
