JD 4010 Hydraulic pump plug
pitwagon
05-21-2008 13:00:36
I have a 4010 that has a plug, wrench size of 9/16 on the bottom of the hydraulic pump. the plug looks to be around 1/2 in fine threads but will not tightened up enough to stop the drip of fluid. Does this sound like the orginal plug, is there a gasket, o ring, etc that might go on it? The plug will thread for enough in the pump to hide part of the bolt shoulder making it difficult to get a wrench or anything to hold to tightened.
jdemaris
05-22-2008 06:28:43
 Re: JD 4010 Hydraulic pump plug in reply to pitwagon, 05-21-2008 13:00:36
It depends on how original your tractor is. The 4010s orignally came with the hydraulic pumps installed "updside down" as compared to later tractors - like 4020s. Subsequently some got flipped around so a pump shut-off could be installed and easily reached from the top for better starting.
If the pump was turned over - like most other Deere tractors - it will have the pressure-adjuster at the bottom - and it is not JIC thread. It is 7/16" diam. X 20 threads per inch.
Now, if the pump is still installed the original way - a small plug facing the bottom is part # R27218 - and it is 9/16" diam. - 18 threads per inch and takes an 11/16" wrench - and sealed with an o-ring.
The photo is the bottom for all later tractors - or if your's has been flipped over.
third party image
Pitwagon
05-22-2008 19:15:15
 Re: JD 4010 Hydraulic pump plug in reply to jdemaris, 05-22-2008 06:28:43
Thanks a bunch for the info. First old JD I have had, but a great old tractor. Last night I tried a 9/16 fine thread bolt, and it fit perfect. With the part # you advised, I can now get the right one. The bolt I tried was 1 in, so most likely need a shorter one, then an o ring. Local JD dealer could not come up with any number. Thanks again, great info.
rexhellwig
05-21-2008 20:28:13
Lets begin by assuming we are talking the early 1960's 4010.
There isn't any pipe thread on this pump. All small plugs are JIC o-ring thread. Take it out and have a look. The threads will be SAE fine. A lot of torque is not needed to seal a plug this size.
There are none that point straight down in this size range. If the pump has been replaced in the past, it will have one about this size near the shaft end of the pump. It will be angled slightly toward the brake pedal side of the tractor. It is for a seal drain line that wasn't used on the original 4010 pump.
jdemaris
05-21-2008 16:58:19
A photo would help - but the only plugs that face down - are at the bottom of the control valve housing at the back of the pump. One large-hex "plug" is supposed to have an adjuster screw and jam nut threaded into it - that is 1/2" fine thread. The original adjuster bolt had an internal-hex Allen head on it. You adjust the pump standby pressure with it and then lock in place with a standard 1/2" nut. Sounds like that's what your're talking about - and it gets sealed with an o-ring.
