24 Volt Generator
KW Gray
05-21-2008 12:19:28
I have a 1961 4010 diesel with 24 volt generator. I restored the tractor 4 year ago and in the process replaced the generator. after three years the generator stopped producing juice. I took to the local Deere dealership and they checked it out and said it needed to be replaced and I did so (last june). I noticed this spring that the new generator is showing a ton of arcing between the armature and brushes and that when I idle the engine down that the dash "GEN" light come on around 900 - 1000 rpm. Is this generator bad or is there possibly something in the wiring causing this problem? Thanks!
LarrySTN
05-21-2008 16:36:52
 Re: 24 Volt Generator in reply to KW Gray, 05-21-2008 12:19:28
That depends on what you mean by a "ton" of arcing. It's common to see arcing at the brushes especially when the batteries are a little low. It is also common to see the gen light glow at idle rpm. If it is charging ok don't worry about it.
