The 60 should be timed at 5� AFTER top dead center for static (or start) timing. I've run 4 different 60's on my dyno and every one that was timed at 0� TDC static timing had ignition pinging at full load! Set 'em to -5 and they bark all the way to way overloaded with no knocks! Deere said -5 static and I guess they meant it! As to the all or nothing with very little throw to the throttle handle... What you describe is usually an over ride feature or doubling of springs, a severely shortened or out of adjustment governor to carb linkage rod or (unfortunately) an internal governor problem. You SHOULD have almost 60� worth of rotation to the throttle handle from dead slow to fast idle so..... First and foremost adjust the throttle linkages as specified! They are rather sensitive governors when working properly! There were variations in the early numbered tractors each having rather specific settings so don't guess. Use a book. When all the way back, properly adjusted and working right, the engine should be at dead idle speed yet still have significant governor action available. If the rod between the governor and the carb broke & was bootleg repaired but is too short, the governor may not be able to slow it down and will cause what you describe to take place. Careful linkage adjustment will identify this if it is the case. Check out the governor spring. Make sure it has not been over ridden (or doubled) by a previous surgeon. If it still misbehaves after all the above, I would disconnect the rod between the throttle lever and the governor spring (leave the governor connected to the carb) and YOU control the throttle setting by hand at the carb. To prevent a runaway, have someone else start the engine. You should at all times feel the action of the governor working to shut the carb down to dead idle. As you make it to go faster, the force from the governor should increase significantly! If you don't feel the governor fighting you, you have an internal governor problem. If the guts of the governor are working you will know it because the force of the governor pushing the throttle to idle position without the spring attached is substantial! Hope that helps. Later.
