4115 lift capability
leon
05-21-2008 10:17:41
Could someone please tell me the published 3-point hitch lift capability and front end loader lift capability of a 4115, MFWD, tractor? Thanks
leon
05-22-2008 07:18:50
 Re: 4115 lift capability in reply to leon, 05-21-2008 10:17:41
Thanks Frank.
Since first posting, I've found that the 410 loader on the 4115 tractor has a lift capability of 800 pounds to full lift height, but of course some more capability if you don't want to lift so high.
The rear 3-point hitch is capable of 1150 pounds at the ASAE standard point of 24 inches back from the hitch balls, or 2350 pounds at the balls.
Mike M
05-22-2008 09:25:16
 Re: 4115 lift capability in reply to leon, 05-22-2008 07:18:50
Just be sure to use PLENTY of counter weight on the rear if using the loader.
F-I-T
05-22-2008 08:27:30
I just bought a 4310 a few weeks ago, and I know that it plays with any three load I have placed on it. It is 3 times as powerful as my 855, and probably rivals the old 70D for lift capability, if you can keep the front end on the ground. The 420 loader works well, and you can stall the tractor with a load in it, so it can out lift the tractor.
leon
05-23-2008 03:10:25
 Re: 4115 lift capability in reply to F-I-T, 05-22-2008 08:27:30
Frank, that wonderful JD book I found shows 2200 lb lift capability at 24" and 2530 lb at the balls for a 4310. The 4310 can use either a 420 loader, 1003 lb lift capability at the pivot pin to full height, or for a 430 loader, 1261 lb at the pivot pin to full height.
