896 Rake Questions
MCL
05-21-2008 08:51:48
Just bought a model 896 hay rake. Paint not great but looks good otherwise. No bends, breaks, or welds. Only one tooth broken. It has the dolly wheel. How old is this thing and any secrets to operating it?
Would have rather had one without the dolly wheel. They ran over windrows for years with narrow front tractors so I guess it won't hurt much.
MoMark
05-22-2008 19:25:44
 Re: 896 Rake Questions in reply to MCL, 05-21-2008 08:51:48
The drive system on the #14 was a simple chain drive in which you engaged/disengaged ratchet gears with 1 lever. I have broken a couple of pivot pins for the ratchet dogs on the JD rake. I wish mine was a dolly wheel, but I fabricated a mount for a Bulldog screw jack & it works quite well. We hay about 30 acres a year, all with antique equipment.
MoMark
05-21-2008 10:38:02
third party image
third party image
Hey MCL, I finally found another 896 owner! Mine is an 896-A, about a '59 model. It was salvage bait when I traded my IH 14 for it. Honestly the IH had a better drive system, but it wasn't green & yellow. Mine has been completely stripped, sandblasted, & painted, with new tires, teeth, bearings, etc...
Operation is pretty straightforward. Engage both hubs. I make a round CCW to get the hay off the fence & then turn around & do the rest of the field CW in a spiral. This gives your windrow a nice flowing radius, even if you make a sharp turn.
I will try to attach a couple of pictures. I have since changed the decals to custom ones from Jorde, with the JD 20 series tractor font, which is what the original were.
MCL
05-22-2008 08:02:10
 Re: 896 Rake Questions in reply to MoMark, 05-21-2008 10:38:02
Mine doesn't look near that nice. I notice some differences. My frame rails don't curve forward where the rear wheels mount. Mine go straight down or maybe angle to the rear. Makes it longer overall. I notice yours doesn't have the dolly wheel. Mine has the small John Deere lettering (20 series?) and the 896 number like the 730 or 4020's had. You say yours is a 59 model. I was figuring 1960's vintage. I am no Deere expert. Most of my stuff is green but a darker shade. Tractors anyhow. I do have a Deere grader blade and #68 feed wagon.
Funny you would mention the drive compared to an IH. My neigbor has an IH rake (I don't know model) and he has all kinds of problems with the drive on it.
James Howell
05-21-2008 17:10:53
That is one nice looking combination of tractor and hay rake.
A lot of work restoring a hay rake.
Good work on both.
