4020 pto parts
jeff in IL
05-20-2008 18:58:37
I am looking for 4020 pto parts to convert a 1000rpm only tractor to 540 or 1000. I need shaft from front to back, output shafts, back bearing plate and gears and short shaft that you can reach from back end. Anybody have any ones they are parting out?
Mike M
05-21-2008 07:03:40
 Re: 4020 pto parts in reply to jeff in IL, 05-20-2008 18:58:37
With those 4020's gaining in collectabilty your tractor is likely VERY rare. Might just be alot better off to just get another one setup like you want. There are companies that make add on gear boxes to reduce pto speeds cause there are alot of large tractors with 1000 only pto's that can be bought cheap.
