Using regular no lead gas in JD 50
gitrib
05-20-2008 13:11:55
Just about ready to fire up our 1956 restored 50 and put it in the field. Had a engineer friend say we were going to have to add something to regular gas if we were going to work it. He claimed they are suppose to run on leaded gas. I did not think it made any difference. Any comments? gitrib
buickanddeere
05-21-2008 19:06:37
 Re: It's all in how you apply it..... in reply to gitrib, 05-20-2008 13:11:55
F.I.T.
Well said.
Sam#3
05-20-2008 22:17:37
 Re: Using regular no lead gas in JD 50 in reply to gitrib, 05-20-2008 13:11:55
Not to belittle people with titles but do you have any idea how many different categories of engineers there are?
My brother is an engineer and before that he was a brakeman. My first son-in-law was a software engineer. I had an old electronic organ built with vacuum tubes. He asked why it had all the bulbs. He also had an old car that used a lot of oil. He thought that because his car needed oil added my daughter's new pickup did also. My daughter called in a panic because of all the smoke. I knew several transmission engineers in the Phone Company but most didn't know much about a hydromatic or square cut gears. And like one told me, "we just copy what the last guy did." Or repeated what they heard in the coffee shop.
I say all this as a word of caution about hearsay and subject matter experts. There's a lot of engineers on this website who can't drive a train and a lot of folks who graduated sixth grade (or didn't) who know a lot about valve seats.
jdemaris
05-21-2008 06:16:59
 Re: Using regular no lead gas in JD 50 in reply to Sam#3, 05-20-2008 22:17:37
I'll add - that there are also engineers around who are not very good even in their own fields of study - when it comes to real-world situations.
There's a big difference between the theoretical and real-world, everyday applications. I've known many degreed engineers that were good at both - and also met many that were totally clueless.
I worked alongside many AG engineers from Deere - trying to diagnose problems with new Deere tractors. Some of them barely knew which end of a wrench to use.
My brother has his doctorate degree, has two computer related engineering degrees, teaches/preaches at MIT, - and can barely send an email - and has never been able to pass a driver's test and get his license. 60 years old and still takes taxis.
Many of the smartest, skilled, and informed people I've know don't even have undergrad degrees, and some lack high-school diplomas.
I went to college late in life (started in my 40s) and got several degrees - after years of working as a grease-monkey mechanic, electrician, and a builder. If anything, it made me dumber and more confused and it took quite a few years for my head to clear afterwards.
tstex
05-21-2008 06:49:14
 Re: Using regular no lead gas in JD 50 in reply to jdemaris, 05-21-2008 06:16:59
jdemaris,
great comments, and as the saying goes, "i do not let my schooling get in the way of my education"
I have a degree or two from a major university, and i believe that effective communication skills are paramount in ALL jobs. Then it takes a case of good common sense to use your advanced education...people that have all of the above are very lucky and skilled people...most engineers lack effective communication skills, but not all...I am ALWAYS open to suggestions and higher/basic learning in any format. That is how i was able to restore my deere when previously i have never worked on anything, other than changing car oil & filters...i hung my ego at the door, listened and followed practice advice.
Good luck gentlemen,
tom
F-I-T
05-21-2008 09:06:14
 It's all in how you apply it..... in reply to tstex, 05-21-2008 06:49:14
I think the more formal education one receives, the more humble one should become. The more I learn, the more I realize that I fully know and understand very, very, little of what there is to know.
I, like many here, have what I feel is an interesting story to tell in the way of "real-world" experience blended with post-high-school education. While I value and use my daily shop experience every day, there is not one day in which I do not reflect on some point of theory acquired in college or in casual reading that saves me the effort in performing an actual test that would have resulted in costly failure.
I think folks should honestly re-consider the entire truth-in-numbers behind these people that were made less-intelligent or socially-disfunctional as a result of increased education. You understand that these people were probably socio-phobic even in their primary schooling, so they were likely to suffer from this confusion whether they ever became degreed or not. Albert Einstein could not remember his own telephone number because he knew it was kept in a book somewhere. Was that craziness or simple efficiency?
These stories sound good when your primary interest is to pat each other on the backs, but in my experience, having had a great deal of contact with some very educated folks who hail from places like MIT to Cal Tech to NASA, I can say that those stories are miniscule, if not so small to be considered nearly urban legend, oft repeated by those who have not earned degrees, so that they might feel better about their chosen lot in life.
If any of you have a child who is or eventually becomes a degreed nurse, computer scientist, doctor, lawyer, genetic researcher, dentist, nuclear physicist, or some-sort-of-engineer, will you tell them that they wasted their time when they could have been out there gaining "experience"?
While I have a great respect for a skilled tradesman, craftsman, machinist, welder, or carpenter, or any hands-on technician for that matter, I cannot reason that any of them would have been or could have been made worse at their trade by some additional formal eduaction.
Does anyone here tell their chilldren each night, "Now pay attention to how I change the oil and gap the plugs. Your mother and I would not want you to disgrace us by going to college..... "
Glen D Anderson
05-21-2008 10:40:54
 Re: It's all in how you apply it..... in reply to F-I-T, 05-21-2008 09:06:14
Not having chosen a path that would have led to a university degree, but rather a path that led to a college degree, I can attest that I do NOT feel insecure or jealous towards others that have a higher degree of education than myself.
I am in no way disillusioned by the belief that I have more knowledge than a neurosurgeon, an engineer(of any kind), or lawyer in their particular field of expertise.
I have always enjoyed learning from people both young and old, formally educated or not, on many different subjects
I agree that everyday I utilize and appreciate the education I've received.
I cant speak for everyone but I can speak for the small demographic that constitutes the average blue collar worker(AKA - mechanic, truck driver, partsman, farmer/rancher, store merchant, plumber, electrician, etc, etc.) when I say this:
I feel frustrated when I am spoken "down to" by someone with a higher degree of education or social stature. I may have been unfortunate that the the majority of my experience has been as such. I realize this is not the case for everone and for those who this does not apply to/ please disregard this.
Also, when my child(or children should my wife and I have more)is/are deciding what type of career/education to pursue, I wont be telling him "dont disgrace you mother and I by going to college or university" NOT A CHANCE, but I also wont be telling him "You dont want to be a dumb mechanic like your old man!" either.
F-I-T, I agree with almost all of what you've said but there are always two sides to any coin.
Glen
Glen D Anderson
05-21-2008 19:56:11
 Re: It's all in how you apply it..... in reply to Glen D Anderson, 05-21-2008 10:40:54
Sorry if my reply made no sense,
As Tom pointed out earlier in his post, good communication skills are a definite asset.
I understood some of the subject of your first post to be you explaining your frustration at those who attmept to minimize people who have gone on to obtain an educational background higher than theirs for whatever reason. I understand this to be aimed at those here on the forum who took "pot shots" at the engineering profession.
If I'm out to lunch, please correct me....
I also understood some of the subject of your first post to be you dispelling the myth that most engineers(or anyone with a high level of education)have difficulty tying their shoes(or as jdmaris' brother being unable to obtain his drivers license)
Again, if I'm wrong please correct me.....
My point was this:
It has been my experience, and that of many others I've known and worked with over the years, that many people(NOT ALL BY ANY MEANS)with engineering backgounds I've come in contact with consider themselves more intelligent than myself. I say this due to way I and the others I've known and worked with were spoken to by these people and how our ideas and suggestions were merely dismissed with the wave of a hand in both the workplace and social settings on a variety of occassions.
I, personally, do not aknowledge social stature when speaking to a person or when chosing friends, so therefore, by your rational I shouldn't be able to be "spoke down" to. Unfortunately, I was, there is no way to mistake it. Until recently, education and social stature HAVE went hand in hand. Right or wrong, that association is still quite prevalent. Now on to the nuts and bolts of my point. There are many people who make sarcastic comments towards those who are more highly educated than themselves, they do so purely out of jealously and insecurity. These same people would be jealous if their neighbor bought a new truck, car, tractor, etc. They would do so rather than being happy for that person. You have undoubtly encountered these types, however I am not speaking for these people.
I am speaking for myself, and others with similar experiences. Perhaps we let the odd comment slip about "the engineer not being able to tie his shoes" even though it's not in our nature to do so, nor do we actually feel this is true. Then again were all human, we have our experiences and that's the point I'm trying to convey.
I think how this applies to the discussion is that some may feel it frustrating that a person would comment on the incompatiblity of unleaded fuel with "cast in head" seats and inferior valves without understanding how the combination will actually work given the load/hours the engine is expected to operate at.
I hope that expalins where I'm coming from.
I agree with you 100%, F-I-T, that no one should pass up the opportunity for further education, education does make life much easier and more enjoyable. I agree that gaining further education does not lead to one losing their ability to perform simple tasks. Futhermore, I can't strain enough the importance of obtaining a good education, especially to the younger generation. Lastly, wisdom does not necessarily come with education/schooling. Wisdom comes with the willingness to learn from anyone who has something valuable to teach and being able to recognize it as such, whether the person is a university professor or an old man sitting in the corner in a bar.
As for the engineers that I've discovered we have on this forum during this discussion, F-I-T and Gerald J, I've always enjoyed reading your posts and have always appreciated the advice you've offered, it has proved invaulable. Also tstex(Tom), I'm very impressed with your comment about "leaving your ego at the door", that sir, is one large step to changing may overall experience with the engineering profession.
F-I-T, I hope your team wins,
Take care,
Glen
F-I-T
05-22-2008 08:25:22
 Re: It's all in how you apply it..... in reply to Glen D Anderson, 05-21-2008 19:56:11
Glen:
They lose, :( ,5-2, played terribly, and clearly demonstrated that they deserve to be in last place.
Frank
F-I-T
05-21-2008 14:50:00
Sorry, Glen, but I truly did not understand your point. No problem, I just did not get it.
I do believe that you can only be spoken down to if you allow yourself to accept that you are in a lesser "social stature", whatever that may mean. I just don't feel that the majority of educated people have begun a slow descent into stupidity and social "ineptitude". I also never said that there was anything wrong with aspiring to be a good and skilled tradesman, but if I believe that, then it follows that there is also nothing wrong with one's pursuit of a quality education. To support either of those points of view is to fall into the trap of stereotyping people and slotting them into foregone conclusions.
I am appreciative of my work experience and the work that I put forth in earning my degree(s). I resent it when someone minimizes either aspect of my life.
Now, to say that someone is a "dumb" mechanic is not true in every case, because if there is a competition, there can only be one dumbest, and by the same token, there can only be one best. But does trying to be the smartest/best mechanic send the fellow down to road to not being able to order a pizza or drive a car? I doubt it. I think that you would get brighter and more clever, not less able.
I read posts on this forum quite frequently commenting about "educated" expletives, and it riles me, but when a fellow has a problem, no experience, no books, takes no time to perform his own research, and then someone steps up and writes out a thorough, cogent reply that explains a complex problem in a simple to understand way, people never seem to feel that they were talked down to, but they also seldom reply to say "Thanks", either.
I was a "blue-collar" UAW worker for many years. Paid for my own degrees before the advent of tuition reimbursement, wanted to do something different, so I planned a path and set out on it. If got I "dumber" as my education credits were earned, my pay checks would say otherwise. I just hate to think of the young people who read the forum and come away with feeling that some posters think that an education might be valued in such a meager way.
Have a good one! I'm going to Dodger Stadium game tonight and watch my (last place - oooph!) Cincinnati Reds!
old
05-20-2008 21:25:36
That lead needed is an old wives tail nothing more. Yes if it was a high compression engine maybe but face it the 50 was never all the high a compression engine. Its been at least 20 years since you could by gas that had lead in it so if the no lead gas was a problem don't you think there would be a lot of dead tractors sitting?? But since we are talking about it on this site I guess there not dead because we use them all the time and show them off and talk about them day in day out. Reason I know for sure its been 29 years is the last time my moms 1965 Chev was driven was in 1986 and the last station that had leaded gas still had it but not long after. When it was parked it had a full tank of gas and it still has that tank of gas in it
jdemaris
05-21-2008 06:04:52
 Re: Using regular no lead gas in JD 50 in reply to old, 05-20-2008 21:25:36
It is not a "wive's tale" at all. Converting to unleaded did cause problems - mostly in third-world countries where old vehicles are used much longer than here.
Fact are facts - and there was a lot of money spent on controlled testing for metal-wear - by the U.S government, by the Canadian government, by the U.S. military, Ford, GM, Chrysler, etc. I've got may pages of test results here - and to sum it all up as a "wive's tale" is hogwash.
Unleaded gas makes soft valve seats wear much faster than with leaded. When unleaded gas first became the law - in the U.S. and Canada, some additives were put into it to offset the wear. That was stopped after a few years. From the early 70s on, just about all engines when built new got hardened valve seats so it became a non-issue -except when used in older stuff.
As all this relates to old tractors? If your tractor still has cast-in-head seats - they will wear faster. But - if you are not using it as a full-time, everyday farm tractor - you probably will not live long enough to ever notice the difference.
buickanddeere
05-20-2008 19:21:45
Maybe if your 50 had a aircooled P&W radial engine and you cruised at 10,000ft. Otherwise use the unleaded and enjoy a longer lasting cleaner engine. Your engineer buddy intends well but is being over cautious.
As previously stated, if you ever managed to work it long and hard enough to wear down the seats. It's fast, simple and easy to pop the head off and freshen it up with hardened seats.
The reduced wear on the rest of the engine more than makes up for exhaust seat concerns.
jdemaris
05-20-2008 17:54:08
The unleaded gas will make the valve seats wear faster if they are still the original "cast in head" seats. If newer hardened inserts have been installed, it makes no difference.
For a tractor not being worked hard, you'll never notice the difference anyway. But - yes - it's been proven with a lot of controlled testing that unleaded gas causes valve-seat recession over time withs soft cast seats.
garytomaszewski
05-20-2008 17:12:01
The tractor was made in the era of lead in gas to improve anti-knock characteristics for high compression engines. If the restoration involved engine work(valve grind) then you might have had hardened seats installed. We have run all kinds of tractors from that era for the last 33 years on unleaded fuel, when they eventually get rebuild we go to hard seats but have no real problems. Unless the additive is real tetraethyl lead ( doubtful;it's poisonous) you are wasting your money
Mark-IA
05-20-2008 15:50:19
When your tractor was built, I don't think they had lead in the fuel.. You'll be fine with Unleaded gas..
F-I-T
05-20-2008 15:57:08
 Re: Using regular no lead gas in JD 50 in reply to Mark-IA, 05-20-2008 15:50:19
Oh, yeah they did. I think Tetraethyl lead began to phase starting in model year 1975 for cars. I know I bought a new '75 Chevy Malibu and it was the first year for the lead-free, catalytic converter equipped engines. So the '50' was produced some 20 years prior to that phase out date.
That said, I agree with Gerald in that you would have to REALLY be working an old gas engine to worry about it at all. I replace the valve seats as a matter of course these days and that gives me some confidence that that the valves will not necessarily recede. Other than that, I would not worry if your rebuild is sound and she runs in the correct temperature range, and the timing is right on the money. I jsut spent two hard weekends working my little VAC Case and she runs like a top, doesn't spit or foul plugs, and pulls really nice, including a recent stint on the dyno.
Frank
Gerald J.
05-20-2008 14:14:41
I'm an engineer too. I don't believe you need to polute the atmosphere and earth with lead in your fuel to say nothing of fowling spark plugs.
I rather doubt you are going to plow a 1000 hours a year. Any valve wear from lack of lead won't show in fewer hours, but will just be enough to keep the valve seats clean.
Most of the so called lead additives aren't really lead but some motor "honey" to empty your pocket book without causing too much environmental harm. And the last thing your stock vintage tractor needs is higher octane fuel. High octane is only needed for high compression ratio engines which your tractor is not.
Save your money and the environment and burn unleaded or E-10 without problems.
Gerald J.
DanL-Colorado B36320
05-20-2008 14:02:04
You say it's restored. Does that mean you rebuilt the engine?
Unleaded gas can be hard on valves and (especially) valve seats that aren't designed for unleaded fuel. If you had the head in the machine shop for valve work, did they put hardened seats in the head? If so, you probably don't need to worry much but if it still has the originals, it might be a concern if you're gonna run it long and hard.
Haywood
05-20-2008 13:40:06
Go to a auto parts store and buy some CD-2 led additive. It will increase the octane and make regular leaded fuel like she should run on.
Your friend is correct.
