4020 electronic timing wiring
groller
05-20-2008 10:47:05
I bought a JD 4020 with a new coil and electronic ignition in it and I believe it is not wired proper. The tractor does not run right. Does anyone know how to wire this up? The tractor is a positive ground and looking up the part on the plate it is listed as -12v.
S.C.
05-20-2008 22:49:16
 Re: 4020 electronic timing wiring in reply to groller, 05-20-2008 10:47:05
I installed one of these electronic ignitions on a 4010 with positive ground a couple years ago and it works great. I'm not sure if a 4020 gas is the same as the 4010 but you need to have a 12 volt coil for the electronic ignition. The stock coil is a 6 volt. There is either a resistor on the back of the ignition switch or a resistor in the wire going to the coil that will have to be removed and a jumper installed so the coil has 12 volts when cranking and running. In stock form, when the key is turned to start, 12 volts is sent to the 6 volt coil to make a hot spark for easier starting and when the key is in run, voltage is going through the resistor to drop the voltage down to 6 volts going to the 6 volt coil. I broke the resitor off the back of the ignition switch and used a bolt and three nuts for a jumper.
John T
05-20-2008 15:03:02
I agree with Bob, if it was wired at reverse polarity it should have already fried n wouldnt work at alllll lllll but you indicate it runs just poorly correct????? ??
If you used a full true 12 volt coil (i.e. No external ballast) the lil module only has 2 wires, one goes to the + side of coil the other to - of coil and you will have to trust Bobs diagram as far as color codes.....but again if its NOT fried it must already be at the right polarity n reversal may fry it !!!!! !!!!!
They time similar to how you time a regular points ignition, its just that instead of a set of points breaking open to fire the coil a lil magnet on the distributor (it takes the place of high cam lobe opening the points) cam triggers the module to interrupt the coils current flow n she fires. Im unfamilair with new generation timing but just use the regular timing procedure cuz a timign light will still work the same and distributor rotation still changes timing etc.
Sure the spark plugs and plug wires are okay????? ???? Id suspect plugs or wires (or timing) instead of the elec ignition if its indeed causing the coil to fire as it should
John T
Bob
05-20-2008 14:46:06
APPARENTLY a Pertronix unit?
If the tractor is wired (+) ground, the electronic ignition unit MUST be made for (+) ground, or the smoke will be almost instantly let out of the module when the ignition switch is turned "ON".
Maybe somebody switched the battery polarity after the Ignitor was bought and installed?
If it INDEED is a Pertronix module, if (+) ground, there should be a BLACK and a BLACK/WHITE wire coming out of the module.
If a Pertronix (-) ground, there will be a RED and a WHITE wire.
