Baler 214W or 224WC
JD Gimpl
05-20-2008 09:05:29
Hi Guys,
I am wondering which one is a better baler. I am only going to be doing 2-3 hundred bales a year. Both balers have a Wisconsin on them and was just wondering which way to go.
Thanks Gimpl
Tx Jim
05-21-2008 04:49:17
 Re: Baler 214W or 224WC in reply to johndeerewoody, 05-20-2008 09:05:29
JD Gimpl
The 214 should have a plunger head stop under the bale case. I would pick a 224 because it has brgs on plunger head instead of wear pads. It is also easier to time as the 214 has a short chain(with no tension idler) that operates the tying system that I thought was terrible to re-time baler whereas the 224 has a much longer chain with an idler. I also think 224 has a brg on plunger head arm whereas 214 has inserts similar to an engine crankshaft. Knotter systems were identical.
SRW
05-20-2008 11:57:15
 Re: Baler 214W or 224WC in reply to JD Gimpl, 05-20-2008 09:05:29
224, If I remember right it has a plunger stop to protect the needles where the 214 doesn't. My dad had both when I was a kid and I remember changing needles on the 214. Thought we were tall cotton when we got the 224WS.
Our 214 had a wisconsin engine on it but the 224 was PTO drive.
