520 - PTO suddenly stuck - searching for answers
Kerry Roberts
05-19-2008 22:34:30
I mowed about 2 acres this morning with my 520 and a JD 38 sickle mower. I crossed the yard to another small field and pressed the PTO clutch pedal forward. It would not engage. I pressed so hard that I think I bent (slightly) the connecting rod to the lever by the right lift arm.
I just changed the PTO oil (used JD 10W oil per specified) and the oil level is still correct.
The PTO shaft would not move by hand, but with gradual pressure with a pipe wrench it moved. However, the foot pedal would not engage.
The engagement lever moves left or right freely (with the engine off) as it should.
Where do I start? There were no weird noises, knocking sounds, etc. Everything seemed to be fine.
Thanks in advance for your help. Kerry
Mel in SW Iowa
05-22-2008 12:55:16
 Re: 520 - PTO suddenly stuck - searching for answers in reply to Kerry Roberts, 05-19-2008 22:34:30
I don"t blame anyone looking for an easier solution.
The square snap ring that I believe is causing your trouble, and that I know caused my trouble
is the square snap ring shown by 2cylLP"s illustration at the bottom of the splines.
If you are familiar with this part of your machine, it is about an hour job out and in if you have parts on hand. I hope your steel and friction clutch discs are ok, because they were very pricey from JD as others mentioned. I don"t remember how much the brake disc is, nor have I
checked aftermarket prices.
Good Luck.
machinery-man
05-21-2008 08:24:06
Those disc are fairly durable...like I advised I would loosen the clearance then get it moving freely and tnen flush the housing then retighten. If that all failed then I"d go with dissambley. Don"t immediatly due brain surgery just because of a headache. If you tear down be sure to snap the clutch disc back together before replacing and also ready to get some big $$$ ready.
Mel in SW Iowa
05-21-2008 08:17:57
I don't have a parts diagram in front of me, but
I had the same thing happen on my 530. There is
a large square snap ring that has popped out of its groove. I think it is located behind the clutch disc pack, between it and the brake disc. When it pops out of the groove on the shaft, it
destroys the friction material on the brake disc. If your friction clutch discs haven't been damaged, you will need complete disassembly, a new snap ring, and a new brake disc.
On my 530, the first time it happened I put a new
brake disc in and reassembled it with the old snap ring. It didn't last very long.
The second time, I replaced a couple of damaged friction clutch discs, used a new snap ring, filed out the snap ring recess in the shaft wider so that it was no longer rounded on one side, and used another new brake disc. It hasn't bothered
again in the last 25 years.
It is much easier to reassemble the clutch pack
and snap the engagement collar forward to hold the clutch discs in alignment if you have a spare
clutch housing basket to slide it into before locking the engagement collar. It can be done
without the spare clutch housing if you securely hold the pto shaft sticking out of the bottom of clutch assembly vertical with a soft jawed vise, align the clutch discs and their ears perfectly with at least two straight edges before you snap the engagement collar over center.
2cylinderlp
05-20-2008 10:59:10
third party image
I think I would bite the bullet on this and do a complete tear down before further operation. You are likely to have some repairs needed in there. There is a tendancy for the springs to break. Although it is more work I would also suggest taking the entire rear housing off so that you can get at the seal that keeps the tranny gear oil out of the PTO clutches. (Unless you know that it has been done) The picture is of the clutch pack from a 730. But the design is the same.
WeirdDeere
05-21-2008 01:45:33
 Re: 520 - PTO suddenly stuck - searching for answers in reply to 2cylinderlp, 05-20-2008 10:59:10
Not to be picky, and I will freely admit that it's been a while since I dived into a PTO...
Is your PTO brake plate on upside down in that photo?
Brandon
2cylinderlp
05-21-2008 05:13:06
 Re: 520 - PTO suddenly stuck - searching for answers in reply to WeirdDeere, 05-21-2008 01:45:33
Well you can bet I questioned that at the time. I was instructed by the vendor that sold me the part that it goes in that way. There is a surface on the other side for the brake to work against that you can't see in the picture. I completed the adjustments and it seems to work properly in the tractor now. But I admit I haven't really used it. I don't know about the 630, but in 530 there is brake material on both sides of the brake plate.
Mike M
05-21-2008 07:16:35
 Re: 520 - PTO suddenly stuck - searching for answers in reply to 2cylinderlp, 05-21-2008 05:13:06
I was thinking ? that the replacement ones I got from Deere had lining on both sides ? It has been a long time though.
2cylinderlp
05-21-2008 22:01:11
 Re: 520 - PTO suddenly stuck - searching for answers in reply to Mike M, 05-21-2008 07:16:35
third party image
I looked at a couple things to make sure this is correct. There is one picture in the manual that I tried to scan and show here. It isn't very good but probably good enough to verify no sign of clutch facing material on side we are looking at. I also looked at the old worn out brake plate. There isn't any facing left on it but there is Glue from when it was originally bonded on one side only. Just bare metal on the other side. The diagram in the parts manual shows a drawing of the brake plate and it is orientated the other way. It shows facing material on the side the way I have it installed. I got the brake plate from WTR tractor parts. I did a 530 at about the same time and the brake plate for it came with facing material on both sides. Naturally that made me wonder if the other one was correct. So I called Dennis at WTR and he explained that the 730 has that facing on just one side of the brake plate. It doesn't make sense to me that the larger tractor would have less pto brake plate surface area. But I guess that is just how it is.
Mike M
05-22-2008 05:24:44
 Re: 520 - PTO suddenly stuck - searching for answers in reply to 2cylinderlp, 05-21-2008 22:01:11
Check with JD and see what they sell. I'm also pretty sure all those parts are the same for all the models you just add more accordingly. I have to laugh at these aftermarket suppliers sometimes they have no clue what they are selling. The carb. kits are the biggest joke ! All the DLTX single bore carbs. (except the H ) take the same parts per JD just 2 different throttle shaft designs. Aftermarkets list alot of different numbers for some odd reason ?
machinery-man
05-20-2008 03:54:53
Sounds like your disk package has locked up inside the drum. I suspect debrie or settlement has bound up the disk. I believe I would drain the drive and flush it out and see if it will release then. You might even want to back off the adjustment to get it free up. This is best approach rather than a tear down. I would say the new oil loosen up clutch debrie and bound it up. I can't recall if the guide say non-detergent or detergent. But new detergent would stir things up.
