858 side delivery rake value?
sep
05-19-2008 13:48:28
Is a 858 rake a good machine? Can you still get bearings and tines??
James22
05-20-2008 20:11:45
 Re: 858 side delivery rake value? in reply to sep, 05-19-2008 13:48:28
I vaguely remember reading a post from someone located in a western state who indicated that that the 858 was a rugged, good rake. A significant upgrade over the cheaper 890 series which was offered during the same period. However I haven't been unhappy with my 896A. Apparently they also used this upgraded implement to rake green peas which is a tough product to windrow. So unless my memory has short-circuited and I therefore have somehow screwed up the model numbers, the 858 would be a good rake. Tines wouldn't be a problem, and I suspect neither would bearings. Call a friendly dealer and ask him to look up a few 858 parts for availability and then make a decision.
Hayfarmer
05-19-2008 18:41:35
I have a 838 and like it for some things. It is good for rolling hay as long as you have enough room between windrows. Have also used it for raking hay and works good. It has a disadvantage to a full 3 point lift on ends. Tines are still available, bearings, depends, I checked on bearings of tine bar ends a couple years ago. Seems like they were available but close to the price of the rake. Lift mechanism had some options. The one I have was originally set up for a cylinder but at some point was converted so it is raised and lowered, the front part, with the drawbar on a 3 point.
