4400 diesal
Mack Casey
05-19-2008 10:53:00
My 4400 has a problem with the diesal fuel valve not opening. It is intermitant. Relay?
Thanks,
mack
machinery-man
05-19-2008 11:04:05
 Re: 4400 diesal in reply to Mack Casey, 05-19-2008 10:53:00
My 4400 has a similar problem and it is with the connection, plug in. I"ve worked on it several times. It will crank but not start, work on plug connection and it fire right up. Recently I used some contact jell plus bent the plug contacts some. The end of plug in doesn"t have any signicant slack and I found by removing the dip stick tube I could get to the plug. I"d like to talk to Deere and see if there is an aftermarket fix or extension. As a matter of fact I think I"ll call the dealer and will post another response if something new is revealed.
machinery-man
05-19-2008 11:09:06
 Re: 4400 diesal in reply to machinery-man, 05-19-2008 11:04:05
just called dealer and no fix, believe the plug just works loose...there isn't much slack in wiring but mess with this and see if that doesn't resolve....
