Tractor really weak in reverse
Joseph with 401
05-19-2008 03:53:36
Can anybody help me? My 1980's 401c tractor is real strong in forward, but barely moves in reverse. Please give me your advice. Thank you!
Roy Suomi
05-19-2008 17:18:30
 Re: Tractor really weak in reverse in reply to Joseph with 401c, 05-19-2008 03:53:36
Put a guage into reverser control valve back cover , plug straight down on bottom..I use a 3/8" nf bolt cut off to about 1/2" long at the threads. Drill it and braze a pipe fitting , install an o-ring to seal it in order to attach a gauge with a 5" long hose..This way you can read the trans pressures while operating the reverser lever..Should read in the neighborhood of 125-135 lbs at half throttle in both forward and reverse..
