B info
souNdguy
11-03-2003 05:34:32
Another update on the genny on my 'B'. 6v is doing great. I got rid of the old 12v battery, and got a new 6v one....and I found out that the oem ammeter in the dash works!.. but was just disconnected. I'm glad I kept it 6v instead of going to 12v .
I did alot of stop and starts with the 'B' this weekend. must have started it 5 times yesterday to move it in and out of the garage to flush and change the oil, and reposition it to work on a leaky axle seal, then re-park in the barn.. etc. Once the battery started to get low from about the third cranking session, the genny really started charging.. about 7 amps or so ( which by the book is about max.. etc... 4-7 amps @ 7 volts according to JD service manual )... so i guess mine is doing great. Also, this 'B' starts so easilly.. I put in new champion plugs.. helped a bunch.
turn on fuel, just crack throttle, spin over about 1.5 seconds and she takes off fine...
Wish my 8N would start that easy...
Soundguy
F-I-T
11-03-2003 05:38:17
 Re: B info in reply to souNdguy, 11-03-2003 05:34:32
Soundguy:
Glad it's charging well!
Which axle seal? If it's the one at the outside end of the rear end housing, that's just a dust felt, and to stop an oil leak, you have to go inside and remove the bull gear to access the seal.
Frank
souNdguy
11-03-2003 06:22:42
 Re: Re: B info in reply to F-I-T, 11-03-2003 05:38:17
I think it was just an overfilled issue.... the tranny/diff oil was 'full to the brim'. I draind and replaced to the correct level, and low and behold.. by this morning the leak was gone...
thanks for the info. I was hoping it was an easy one.. as I had looked at the service manual, and knoew this would be more than a 'one beer' job.. etc....
Soundguy
