Bird Nest in gas tank
Ivan in Mich
05-18-2008 19:06:47
Anyone know how to get a bird nest out of a gas tank. I bought a 1951 B today and was told it was set up. When I got it home I put a battery in it and it rolls over and has fire but the gas tank is full of bird nest. This trac was stored in a barn and because I cannot see the bottom of the tank I don't know if there is any rust in it.The woman I bought it from said her husband bought it new and she has the orignal bill of sale and owners manual for it if she can find it. I got it real cheap because she wanted it gone. Thanks for any help I can get on removing the nest.
GeorgiaHayFarmer
05-19-2008 11:04:28
 Re: Bird Nest in gas tank in reply to Ivan in Mich, 05-18-2008 19:06:47
I'd go find that bird and ask politely if it would go back in that tank and remove the nest...Sounds like you got a good deal on an old tractor.
Scott
Ivan in Mich
05-19-2008 06:53:26
Here is an update. This morning I went out and added a 1 gal tank to it, pulled the carb off and put one back on it from another B I had, added gas and it started right up. I run it down the driveway and back and everything seems to work. Now I will get the carb rebuilt and the nest out of the tank and I should be all set. I am feeling like I stole it because I only gave the owner 150.00 for it as that is what she wanted but she set the price so I guess she must be glad it is gone. Thanks to everyone that replyed and I will put your info to good use. Ivan
RonMC
05-19-2008 10:08:20
 Re: Bird Nest in gas tank in reply to Ivan in Mich, 05-19-2008 06:53:26
Nobody has mentioned the pick-up tools you can find at the tool stores. I have several from my years in the trade and I think one of the press-type with 4 fingers would do a good job of getting out the biggest part of it. Hope this helps, Ron
Mike M
05-19-2008 08:08:24
Just be glad you got a good deal ! Sometimes even if you get one for free they still aren't doing you any favors because it takes more in parts than they are worth ! BTDT !!!
F-I-T
05-19-2008 06:19:03
I had identical situation on our '48 "A". I started with a coat hanger wire and hooked out what I could, then used a vacuum cleaner, but eventually I had to take the tank off because there will be some material stuck to the upper sides and the under the top surface, and if you let that stuff behind and the gasoline starts to swish, it'll get knocked loose.
I filled the tank with hot lye water to dissolve the varnish and organic stuff, and then I went through the steps of rinsing, and agitating with a handful of nuts and bolts or a short length of chain. You can get it cleaned up, but it will take some work.
I wrote up a procedure that I use. You might find it helpful.
Frank
Mike M
05-19-2008 06:09:31
For now I would rig up another tank just to see if you can get it up and running so you can check it all out. You may find other problems that might require you to remove the steering shaft and then the hood then that would be the ideal time to remove the tank and then clean it out.This will also let you inspect the top of the tank for rust through from the outside as this is too common. I have a metal gallon can that I soldered a valve in the bottom and poked a hole in the lid for a vent. The handle on it is nice to use to wire it up to say the air stack ? or even set on a ladder beside the tractor.
Andy Motteberg
05-18-2008 22:10:37
Drain the fuel and remove the tank and try to get the nest out.
jjamna
05-18-2008 21:06:21
If it is good and dry, No gas in it for a while, I would use a shop Vac. Don't do this if there is any possibility that there are fumes. Could go Boom
RobMD
05-18-2008 19:28:56
Take the tank off and stick a power washer in there. You'll eventually break it down good enough to get it out of there with a garden hose.
Then, assess your rust damage.
