4020 electrical question
dflansy
05-18-2008 19:03:58
On my 4020 heres what happens: when the key is on only the gen. light shows, when the key is on and light switch are on the fuel gauge and oil pressure light come on then, and none of the lights work. I checked the voltage at the light switch and it is at 24v should it be at 12? and if it is does that mean the voltage regulator should be replaced? Thanks
GeorgiaHayFarmer
05-19-2008 03:36:41
 Re: 4020 electrical question in reply to dflansy, 05-18-2008 19:03:58
Wanna see tractor electrical go crazy. Start disconnecting grounds and watch it take the path of least resistance through some of the fender light elements. The more good clean grounds you have, the better off you'll be sometimes.
Scott
Bob
05-18-2008 20:40:00
Gerald is correct. Also, it is NORMAL to see 24-Volts at the light switch, as 1/2 of the lights are operated of of 12-Volts (+) ground, and half from 12-Volts (-) ground. There are TWO battery feeds to the light switch. It is just the "chassis ground" you are missing.
Gerald J.
05-18-2008 19:31:17
The wire that connects the common point between the batteries to ground is open. Sometimes it has a fuse. If so the fuse is blown.
Gerald J.
