John deere 3020 Ignition Problem
Joe Bardel
05-18-2008 18:25:15
I was wondering if anyone could help me. I have a John deere 3020 gas tractor, and it runs great, but the generator lite stays on after I start the tractor. Could someone advise me what the problem could be. It doesn't seem to draw down the battery when it is running, so it leads me to think the generator is working. Any help would be great.
Bob
05-18-2008 20:42:05
 Re: John deere 3020 Ignition Problem in reply to Joe Bardel, 05-18-2008 18:25:15
You need to check the batterry voltage after it's run a for a bit at above idle speed. The battery voltage under those conditions needs to be in the 13.8 to 14.5 Volt range.
Joe Bardel
05-19-2008 18:45:02
 Re: John deere 3020 Ignition Problem in reply to Bob, 05-18-2008 20:42:05
Thanks, if it isn't, is it the generator or the voltage regulator.
Thank You,
Joe
Bob
05-19-2008 20:15:58
 Re: John deere 3020 Ignition Problem in reply to Joe Bardel, 05-19-2008 18:45:02
If the voltage is low, try gounding the "F" terminal at the generator (TEMPORARILY, for testing).
If that brings the voltage up, it points to a regulator or associated wiring fault.
If the generator STILL doesn't charge, there is a problem with the generator.
RLFox
05-18-2008 18:50:54
Mine was doing that too, turned out it wasn't charging the batteries. You might not notice them going dead right away, if all you use them for is starting the tractor.
