650 charging / electrical issues
Eric1
05-18-2008 15:25:36
I"m attempting to help a friend work on his 1980"s JD 650. It appears to have two, maybe related, issues.
1) The battery is not being charged. Purchased new battery and still not charging. I read 14VAC & 0VDC with my multimeter coming off of the alternator.
2) Short in the wiring someplace. The "indicator" fuse blows instantly.
Interesting to note that I have continuity between ground and ALL of the fuses except when I turn the electrical knob from off to any of the light settings.
Are their wiring diagrams available online for this tractor?
Thank you, ANY help would be appreciated.
d. coleman
05-20-2008 19:42:55
 Re: 650 charging / electrical issues in reply to Eric1, 05-18-2008 15:25:36
see if your alternator has a diod board inside, most alt. use diod in a triple setuo to change a/c current to d/c by dropping half of sine wave to ground.sounds like your diods are shorted or open if you are only getting a/c readings. most auto zones or similer auto parts stores can check your alt out put.
RobMD
05-18-2008 15:40:24
There is an external voltage regulator on these tractors that often fail after a certain amount of hours. It is usually an aluminum flat thing with many ribs on it. Not sure of the location of it on a 650.
Eric1
05-18-2008 15:46:19
 Re: 650 charging / electrical issues in reply to RobMD, 05-18-2008 15:40:24
Thanks RobMD....yes, I see the external voltage regulator. Would you happen to know how to test it?
RobMD
05-18-2008 17:02:09
 Re: 650 charging / electrical issues in reply to Eric1, 05-18-2008 15:46:19
It should be putting out 14V DC on the output lug. I don't remember the location of this, but i'll tell you what, you can buy one and take it back if that's not it.
Mike M
05-19-2008 06:28:15
 Re: 650 charging / electrical issues in reply to RobMD, 05-18-2008 17:02:09
I doubt ANYBODY is going to let you return electrical parts.
jdelozier
06-02-2008 20:02:17
 Re: 650 charging / electrical issues in reply to Mike M, 05-19-2008 06:28:15
I bought an owners manual off ebay for around $40. There was also a shop repair manual for $150 that the JD dealer said he could order.
Eric1
05-21-2008 05:43:21
My local JD dealer said the voltage regulators never go bad and it is NOT returnable if I buy it. The believe the short is causing the charging problem, and it may be. They also said there are NO wiring diagrams and NO service manuals available for this tractor. At this point, I don"t believe everything they say. I"m just going to have to trace each wire.
Mike M
05-21-2008 11:28:12
 Re: 650 charging / electrical issues in reply to Eric1, 05-21-2008 05:43:21
Deere does offer a service manual for these and it DOES have a wiring diagram in it and those voltage regulators DID have a big time problem with them in the early years as the replacements were made differently. If yours is an early one I'd surely replace it. Post a picture of it. I can compare it to the one on the 750. I may even have the old one laying around ? I think the old ones were black or painted ? and the replacements were plain aluminum.
Eric1
05-21-2008 16:34:54
 Re: 650 charging / electrical issues in reply to Mike M, 05-21-2008 11:28:12
Yeah, that"s why I don"t believe my dealer. I have seen the service manuals for sale and I figured they would include wiring diagrams. I do have a picture of the Voltage Regulator in my JD 650....I"ll try to attach a link to the photos.
Mike M
05-22-2008 14:17:29
 Re: 650 charging / electrical issues in reply to Eric1, 05-21-2008 16:34:54
I found my old original regulator. It is plain finished aluminum and the fins go vertical. So I do believe the one you show is the "newer" type yours has horz. fins and a black finish. I think you have a wiring issue or possible switch problem ? These early regulators would fail and the charge lamp would just flicker and barely go out even at fast speeds.
Mike M
05-22-2008 05:36:10
I'll have to go look at our 750. I should have the new and old laying around ?
