SWEPT-BACK FRONT AXLE
Kenny N AL
05-18-2008 13:27:37
Can someone tell me what is the purpose of swept-back axles on the New Generation tractors. I have a 1530 with this arrangement and was wondering if there is an advantage in having the swept-back over the typical straight axle.
RobMD
05-18-2008 15:17:06
 Re: SWEPT-BACK FRONT AXLE in reply to Kenny N AL, 05-18-2008 13:27:37
Makes a tractor with a loader more unstable, is what it does. Bad combination.
SMinWi
05-18-2008 15:56:38
 Re: SWEPT-BACK FRONT AXLE in reply to RobMD, 05-18-2008 15:17:06
I have a 1520 with a loader on it, and it a a swept back front axle. Nothing unstable about it!!!!! !!!!! !!!
RobMD
05-18-2008 17:05:57
 Re: SWEPT-BACK FRONT AXLE in reply to SMinWi, 05-18-2008 15:56:38
Then you're not exactly using it.
Look at it this way, the axle is set back further away than if it were a straight axle, therefore the rear tires come off of the ground a lot easier than if it were a straight axle.
Kenny N AL
05-19-2008 06:22:41
 Re: SWEPT-BACK FRONT AXLE in reply to RobMD, 05-18-2008 17:05:57
Logically, this makes sense but I'm certain that many tractors with the swept-back axle was sold with loaders, and one can only hope that the operator uses good sense when attempting to pick up a load with their loader. That kind of goes with any loader/axle configuration, but having the front tires set back several inches would logically reduce it's load bearing capability. However, JD must have had some purpose in mind when they designed it. I'm just curious as to what it was. Obviously, it wasn't a big hit, because I haven't seen it on any of their tractors in the last 15 - 20 years.
backwoodsfarm
05-18-2008 13:29:27
I believe it gives you a tighter turning radius. Other than that I'm not sure.
