37 B mag has no spark.
chad from michi
05-18-2008 05:17:27
I stopped and made a list of what I needed to get my B home. I took the plugs out and rolled it over and I had no spark on either plug.
Is there something flipped to kil the mag so the tractor shuts off? Or do I need to look into the mag and check the poitns?
Also I see lots of Unstlyled B's with no fenders is this normal? Or are the original fenders worth some good money? If I end up selling this tractor I just want to know what I have.
thanks for all the help!
old
05-18-2008 10:29:49
 Re: 37 B mag has no spark. in reply to chad from michigan, 05-18-2008 05:17:27
Probably just a set of points that need cleaned or replaced as far as spark. Now as far as fenders they where and option when the tractor was new and few farmers wanted to spend the extra $$ to buy them. But back then money was as tight or tighter then it is now. My 1935 JD-B never did have fenders on it and never will because I plan to leave it as close to what it looked like when my grand father got in in 1940
Anderspm
05-18-2008 06:39:02
I doubt that you have a kill switch on your mag. So you will probably need to take the cap off and take a look inside. Best thing to do if it hasn't run in a while is to just replace the points, condenser, and rotor.
You do see alot of Unstyled B's with the fenders off, farmer would just take them off and put them to the side in the barn. To find originals is very tough and expensive! If you want fenders you would be better off buying new ones.
PBrowning
05-18-2008 05:38:28
I recommend you begin to purchase some literature -- manuals for the tractor and there are specialty manuals on magnetos on eBay all the time, both in book form and on CD. Ones on CD have a whole lot more data.
Yes, the most basic of basic stuff for magneto servicing is to ensure the points are clean and set to something like 0.015. While you have the distributor cap off, also examine the rotor and also make sure the entire cavity is clean and dry -- all this visual. You may have a leaking, shorted or open condenser. They aren't expensive and it would be a good investment. From there you check your wires also -- this should give you an idea.
But until you become more experienced in magnetos, I don't recommend "digging in" beyond points, condenser and rotor & cap inspection & cleaning.
You can learn a bit more over at the JD-H Restoration Site (below). Once there, scan across to ARTICLES 1, and from the drop-downs, select ELECT SYSTEMS.
While at the site, look also (under ARTICLES 1) at the piece called DEERE PUBS. There, on page 2 you will find your tractor and the Deere Publications still available; and at the bottom of page 1 you are shown how to get them.
(PatB)
