730 D .......Pull'n !
Scotty1
05-18-2008 03:17:29
I'm thinking of pulling our old 730D out of the bushes and try to get her fired up. It's not been started in about 10 years. I live in a very small town. About 10 miles away they have a old Fair Ground where they are starting to do some pull'n with older tractors and it looks funner than watching 2 buzards mate ! Think'n would like to give it a try. Are these tractors good pullers and can they be modfied to make more power if needed without break'n the bank? and speaking of break'n will they stand up to the pull'n part ? Thanks for yor time and help.
Scotty1
K.C.
05-18-2008 14:55:30
 Re: 730 D .......Pull'n ! in reply to Scotty1, 05-18-2008 03:17:29
There is a little round cover on the flywheel side of the engine that you pop off, then loosen the lock nut and unscrew the bolt a few turns. This turns up the fuel, and is about the quickest and easiest thing to do before pulling. Also remove the oil from the air cleaner. Get a set of 16.9-38 tires that are road worn, put it in 1st gear, and have some fun.
Mike M
05-18-2008 05:40:04
By all means get it up and running. But you will find out those will pull in the field better than most, but on the track they fall short. John Deere's have never been great for the track as they are too heavy. Too many people running heavily modified tractors in the stock classes as well.
