6410 Hydraulic Indicator light
Rochelle
05-17-2008 21:16:14
The Hydraulic fluid indicator came on, so we changed the Hydraulic fluid and filters, but the light is still on. Any ideas what is wrong?
powertech84
05-18-2008 07:00:55
 Re: 6410 Hydraulic Indicator light in reply to Rochelle, 05-17-2008 21:16:14
you need to check the trouble codes to see if its a pressure, or temperature problem to know where to look.
Rochelle
05-18-2008 11:21:04
 Re: 6410 Hydraulic Indicator light in reply to powertech84, 05-18-2008 07:00:55
Where do you find out about the trouble codes? It doesn't appear to be a temperature problem because the light comes on as soon as you crank the tractor up and remains on the entire time its running.
