730D
Scotty1
05-17-2008 20:21:09
Hi, can someone tell me how much hp a stock 730D is suppose to have ? Thanks for your time and help
Scotty1
Scotty1
05-18-2008 13:36:09
 Re: 730D in reply to Scotty1, 05-17-2008 20:21:09
Thanks everybody! I pulled the Beast up to the shop today. For now I'm just happy the engine isn't stuck! I don't think this thing has been touch in about ten years and the engine still turns over by hand at the flywheel. Lucky! The exhaust had a old tomato can on top of the exhaust pipe but it had been there so long that it had pin holes in it and had leaked water in the exhaust but where the exhaust bends under the hood it had holes in that bend and I guess it would let the water out cause she ain't stuck! For now I think I start with draining the oil and fuel. Also I guess I should pull down the injectors to see whats going on in there. Thanks again
Scotty1
buickanddeere
05-18-2008 11:03:11
And Freddy. How is that helpfull or accurate info? Did you know if the rack is cranked up the HP level will drop due to an over rich condition?
Did you know that any diesel that is overfueled will smoke and burn more fuel per hour per HP than a tractor running at peak efficiency?
freddy
05-19-2008 07:55:16
 Re: 730D in reply to buickanddeere, 05-18-2008 11:03:11
You can get cheap horsepower from a lot of different ways, but they might not be the best ways. Turning up the fuel has been a way of life for the entire John Deere enthusiast from where I live. Both of my friend Gary�s 4455 are making 175 HP. Set on the dyno at JD. Growing up around the 4630�s you would see them smoking a mile away. Were they hard on fuel? Oh absolutely, they were wasteful and terribly hard on the engines longevity? Most likely, but it�s there tractor.
1936
05-18-2008 03:35:01
JD Data book 53.6 HP drawbar. Same for 720 D.
Scotty1
05-17-2008 20:35:08
Thanks guys. How hard is it to make more hp without pulling engine down?..... Maybe Injector opening pressure????? Thanks
Scotty1
freddy
05-18-2008 07:56:45
 Re: 730D in reply to Scotty1, 05-17-2008 20:35:08
I have heard from a guy at john deere with good injectors and the rack set as high the as it will go and the rpm tweeked will make 75 horsepower. He even said he dynoed it at that power. He also said it used fuel like crazy and smoke like a coal locomotive.
J Dean Adams
05-17-2008 20:26:59
Your 730D was rated at 59 Horse power per my records from the Nebraska tractor testing. My is also a 730D.
Good luck with it.
Deano
Mike M
05-17-2008 20:26:14
60 hp
