1946 Model A
Mark Poss
05-17-2008 19:06:01
I looked at a model A today that was advertised as a 1951. The serial number was 574497 I looked it up and according to the book its a 1946. The axle had john deere casted into it. What year did they stop doing that? Thanks Mark.
CLW
05-19-2008 06:15:45
 Re: 1946 Model A in reply to Mark Poss, 05-17-2008 19:06:01
Serial number 583326 was the last A built with the letters in the axles on Feb. 4th, 1947. The one you are looking at is a 1947 styled A.
James Howell
05-18-2008 20:59:03
Several features can help identify the 1946 A:
John Deere "embossed" on the rear axle.
Pan seat instead of battery box seat.
Rear light under pan seat.
Foot pedals for hydraulics under pan seat.
third party image
The motor should have the compression relief "pet cocks" on the outside.
Cast frame instead of "pressed" frame.
third party image
All fuel tractor with 3 way fuel valve and two tanks.
The slant dash.
third party image
Maybe a yellow fan.
third party image
Hope this helps.
The Dukester
05-18-2008 16:03:22
The late styled A models (late '47 on up-pressed steel frame) do not have "JOHN DEERE" cast on the rear axle housings, all the earlier models, styled and unstyled, do. The upper backrest cushion plate on the late styled A's battery box seat has the JOHN DEERE decal to identify the tractor's make from the rear.
alabamafrog
05-18-2008 06:18:09
Mine is a 1947 acording to the number, starts with 59. It does not have the cast John deere on the axle and it has a round axle. It is a styled tractor, I thought the unstyled ones have the cast name and the styled ones did not?
Dave in SV
05-18-2008 05:36:11
I have a '49A, so sayeth the serial number chart... and it does not have John Deere cast into the axle housing. I wish it did, that looks cool.
Ford 312
05-17-2008 19:28:30
I believe they quit casting John Deere in the axle housing in 1950, when they went to the square housing. My 1948 B has John Deere cast in the round axle housing and I believe this was continued through the 1949 model.
