unstyled B wheels original?
Larry Dech
05-17-2008 15:28:06
The 37 B I'm restoring had originally come with steel wheels, but my grandfather at some point changed it over to rubber, on rear cast wheels and front pressed steel wheels. I've gotten conflicting info online as to whether the current set-up was available in 1937...anyone know for sure? Thanks!
Duane Larson
05-17-2008 19:14:28
 Re: unstyled B wheels original? in reply to Larry Dech, 05-17-2008 15:28:06
Larry,
The unsB had cast wheels with 10-spline cast-in hubs available starting at s/n 27435. The wheel had a casting number B695R, and used the B25R hub clamp. Cast wheels with bolt-in hubs were available from 187399 on, with wheel casting number A3149R and the 10-spline bolt-in hub casting number was B2187R. This cast wheel was also used on the styled A.
Pressed steel front wheels became available at 29631 and used a B918R cast hub. The earliest version of this wheel used 10 rivets to attach the rim to the wheel center and was used until mid-'38, when they went to a different (fluted) wheel center that used 8 rivets (2/flute). The last version of this wheel started in early '40, and used the same 8-rivet scheme, but now had 4 "slots" where the wheel center did not touch the rim. All three versions were non-reversible and not stamped with a part number.
Larry Dech
05-18-2008 06:38:55
 Re: unstyled B wheels original? in reply to Duane Larson, 05-17-2008 19:14:28
Thanks Guys!
I"ll go check those casting #"s...
Any recommendations as to where to get the tires?(need all 4,and I"d like to be as true to the original as possible)
ricky c
05-19-2008 04:56:44
 Re: unstyled B wheels original? in reply to Larry Dech, 05-18-2008 06:38:55
third party image
i want to put rubber tires on by 36 B and want to get rid of the steels.i would be interested in a trade if you close by south carolina. thanks ricky
Larry Dech
05-21-2008 12:28:10
 Re: unstyled B wheels original? in reply to ricky c, 05-19-2008 04:56:44
Ricky,
Since my wheels have the cast-in hub, they must be the 695R (older)ones. The centers and rims have been cleaned and painted, but the hub clamps and related hardware are still 'original' (greasy, rusty).
If you're still interested in a trade, I could easily get them to Charlotte, NC. is that close enough to you?
If interested, give me your e-mail address and I'll send you pictures within a couple weeks.
Thanks, Larry
Larry Dech
05-19-2008 10:01:26
Ricky,
I'm in PA and am definitely interested...please note that my wheels have no rubber on them, and I haven't yet checked the casting #'s for originality. (The tractor's stored a couple hours away.) I'll get you pix as soon as I can.
Is there any way you can confirm that your steels would have been stock on a '37 (are there casting #'s) ? Thanks,
Larry
Gary from Muleshoe
05-17-2008 16:09:01
The John Deere Tractor Data Book by Lorry Dunning does not specifically say for the 37. But it does say the 38 to 40 came with the option of skeleton or flat rim steel spoke wheel. Indicating to me that your would have been round spoke.
Gary from Muleshoe
05-17-2008 16:08:58
Mark-IA
05-17-2008 15:54:25
The rear cast wheels were available for the 37 B. I think they are hard to find though. Pressed front wheels were a common option. I'm sure Duane Larson the wheel guru will chime in.
