My experience on the two cylinder diesels, which have a relatively short exhaust path when compared to cars and trucks, is that slobber begins when they exceed the wear limts of bore clearance, ring edge wear, ring land width, etc. Most folks think that this oily mist is diesel fuel, but I am pretty certain that it is motor oil not being scraped properly by rings, loose valve guides, etc. So I say that the slobber you see is actually the heavier motor oil spritzing out the stack and causing the black "measles" that all of us got if we were driving a mostly owrn-out two banger diesel. I have worked on many that slobbered, and no amount of working them ever cured a wornout engine. On the flip side, no amount of idling ever made a new or recently overhauled one slobber. I don't know that I have read from a manufacturer that it is "a proven fact" that a lightly worked tractor diesel engine will slobber. I have a recently majored 70D (150 hours since re-bore, pistons, all injector/pump work, everything that you can do), and if it putters around for me on and off for three months, it puffs nothing but clean exhaust, and if I put the bush hog on it or the disk plow and go deep through roots in the wood lot, it only gets hotter and burns more fuel. Same exhaust. You won't see oil out of it when it is babied, or if it gets heavily loaded. So, I've never cured one of slobber without going into the engine and setting things right. Hard work might get our beer bellies in shape, but I have found that only money will cure the diesel slobbers of a two cylinder engine. I have a pto dynamometer, and there is no method of loading a tractor engine that wll work one harder. I mean it will burn any paint off of any muffler, any time, and I have put a 70D on it that had the slobbers, and it did not seem to improve the slobber one iota. After the first hour she was so good and hot, that it seemed that the oil misting was decreasing, but further examination pretty much has me convinced that the pipe and stack were now so hot, that some of the oil exiting the engine was being partially burned up in the stack, so it seemed that there was less oil. Oil consumption, however, was still the same. Now to the opriginal question, as to why would one slobber at idle and not WOT? It is probably right on the ragged edge of being worn too much, so that at idle the pipe and stack are cool which shows the slobbeirng, but when the stack is hotter, that minimal slobber might be getting burned up, or it is being blown farther away and you aren;t noticing it. It might have the pump timing off just a tad, or the injector breaking pressure in need of tuning in, or even needs an injector/pump rebuild. But my money would bet that the engine has some significant time on it, and it will only get worse until it gets new rings, sitting in nice tight ring lands, and if the slobbering goes away, but it still smokes, then go through the pumps/injectors. My two cents. Frank
