Battery
R.C.
05-16-2008 18:18:03
How long will Jd. 50 run on the battery when the generator is not charging will it make it back home about 3 miles ?????
Thanks
R.c.
buickanddeere
05-17-2008 07:27:36
 Re: Battery in reply to R.C., 05-16-2008 18:18:03
Just put a 12V regulator on the old 6V generator. It should keep the battery topped up.
John B. NE Ind
05-17-2008 03:37:08
Our 8-n we bush hog with doesn't have a charging system. Since it was converted to 12 volts, it starts so easily that we just put it on the charger once every week or two. If you use the lights on a reagular basis naturally you'd have to charge it more often. The battery has been in it for 5 yrs. already with no problems.
old
05-16-2008 19:22:31
Well it depends on how good the battery is and if it has a full charge. If its a good full charged battery it will run you all day for 2-5 days, if you don't use the starter much. I have a gray tractor that the battery lasts for weeks on it with no charging system. One of those days I'll get around to fixing that problem but its been 3 or 4 years now so maybe one of these days I'll get to it
Hoss in Me
05-16-2008 19:04:25
It will run all day! Hoss
RobMD
05-16-2008 18:50:36
you'd probably have other problems before you have a battery going dead in 3 miles.
Just don't use the lights.
jd b puller
05-16-2008 18:36:40
 Re: Battery in reply to J Heitkemper, 05-16-2008 18:18:03
I wouldn't stop and eat a big dinner with it running or anything, but if you're battery is decent, you'll be fine.
