41 B Magneto lost spark
Johnsdeere
05-16-2008 17:52:43
I need some help with my 41 B hand start, it sat over the winter and it has no spark, points dont look burnt and rotor looks good also. Where do I start to check out a mag and what do I look for? It always works well in the past.
Johnsdeere
05-17-2008 10:25:38
 Re: 41 B Magneto lost spark in reply to Johnsdeere, 05-16-2008 17:52:43
Got it running, cleaned the points, and all the terminals and it fired up. Thanks
John T
05-16-2008 19:48:20
First of all is the mag snapping as you rotate the flywheel??? Thats the sound when the spring winds up n then she trips..... ....If the impulse spring never winds up n trips she will never fire at cranking speeds although it may be able to start n run fine if pull started. If she is snapping then clean the points n check their gap as Mike n Old advises cuz a film of oxide coating can stop a mag from firing. If she isnt snapping the engage dogs may just be stuck/corroded (from siting and moisture) and never extend outwards to wind the spring which a good clean up n light lube may cure the problem
John T
John T
05-16-2008 19:47:27
John T
John T
05-16-2008 19:47:27
John T
old
05-16-2008 19:18:52
As Mike says. Common for that to happen if they sit that long. Clean or replace the points and you will probably be back up and running
Mike M
05-16-2008 18:01:21
Run a clean white piece of paper through the points to clean them,you may even have to use some 600 grit if they are scumed over. A good chance you will be back in business.
