'47 Jonn Deere B
pavlock2110
05-16-2008 14:40:29
How do I check the oil on a 1947 John Deere B?
jd b puller
05-16-2008 18:35:11
 Re: '47 Jonn Deere B in reply to jeff in IL, 05-16-2008 14:40:29
johns48jdb said: (quoted from post at 21:41:28 05/16/08) feel under the bolt for a small hole or look under them if your able. nice place for a mirrow, just to be sure your on the right bolt and you want have to worry about where your turning the right one or not. hate to see you lossen the wrong one up and the engine be low of oil and you run it. by the manuals for your tractor. get the parts, owners and shop manula. makes better things to do at night than argue with the little woman. every day that you don't learn something is a wasted day.
Johns48 - thanks for clarifying my post, yeah, guess I was a little vague, eh? :lol: I can see it now, unscrewing the wrong bolt and not getting any oil. Just keep adding till it's running out the belt pulley...
Kind of like my neighbor that put 6 quarts in a riding lawn mower. Came and got me cuz it was smoking "a little". Blowing oil out the muffler.
johns48jdb
05-16-2008 17:41:28
 Re: '47 Jonn Deere B in reply to pavlock2110, 05-16-2008 14:40:29
jd b puller
05-16-2008 16:13:18
Under the Belt pulley (RH Side), there"s a check plug. It"s a bolt essentially, when you unscrew it, if there"s oil in there, it will run out.
old
05-16-2008 14:54:08
Not sure if a 47 would be the same as my 1935 but if it is just under/behind the flywheel there will be a botl sort of thing that you back out a few turns and if you have oil dripping out the hole that you will open up then it is full if not you need to add oil
Mike M
05-16-2008 18:09:58
 Re: '47 Jonn Deere B in reply to old, 05-16-2008 14:54:08
Old; Same way just on the other side cause the fylwheel cover covers up the whole LH side on the late ones.
old
05-16-2008 18:59:09
 Re: '47 Jonn Deere B in reply to Mike M, 05-16-2008 18:09:58
I figured I would be close. I know my my D its under the clutch pulley
