60 oil leak
DGK
05-16-2008 04:32:44
Just changed reduction gears on 60 JD, now throws oil out on inside of clutch drum. Didn"t before. Tractor runs good, no smoke, hardly any blowby. Thanks for any help. Doug
Dennis Andres
05-16-2008 19:59:10
 Re: 60 oil leak in reply to DGK, 05-16-2008 04:32:44
My 60 was throwing oil and the reason was that the gasket was on wrong and covering the hole draing the oil slinger.
Phil Morris
05-25-2008 00:14:37
 Re: 60 oil leak in reply to Dennis Andres, 05-16-2008 19:59:10
DGK was referring to my tractor and, thanks to you, the problem was easily solved.The gasket was covering up the hole. Runs great now. Gives me the shivers when I think of what we might have done to correct the problem but, no matter what we had done, the problem would have still been there without changing the gasket around. Thanks again. Saved me a bunch of money for a major repair.
BushogPapa
05-16-2008 11:24:11
Are you sure you re-installed the sheetmetal "oil scraper"..?? It is shaped a little like an oil trough, to direct oil back and away from the gears and clutch opening.. Maybe the oil didn't have enough time to settle down into the transmission before you started it..?? Sometimes the oil in the 1st reduction cover takes a while to find a level with the oil in the transmission.. That is about all that will cause oil to be thrown out...assuming there is not a lot of crankcase blow-by..
Mike M
05-16-2008 05:01:07
Oil may not of been full enough before or is too full now ? It does take same oil as rear end gear lube also. Is the drain back hole open in the dust shield ? Was that shield removed ? and if so was it recentered ? Even if all the above is correct it seems that if you pull one apart and clean all the old gook out then they tend to throw out some oil. The old gook helps seal them up I guess ? plus if out in the field the dirt and dust will collect and absorb it up forming the before mentioned gook.
