John Deere A starter question
Todd
02-20-2000 18:16:16
The starter on my A really turns over slow with a new battery. Is this generally the need for new brushes, and if it is where can you generally get them. Most of my experience deals with the tractor engines and not starters
Buckeye al
02-21-2000 10:09:27
 Re: John Deere A starter question in reply to Todd, 02-20-2000 18:16:16
Make sure all connections are good connections. I'd remove the starter, look at the condition of the starter switch, connector bolts, their tightness and the brushes. While there, look at the straps that radially connect the commutator bars to the armature windings. I have re-soldered many a commutator bar to the windings. They get overheated by extended cranking, 12 volt jumps or both. They'll get so hot the solder melts and centrifugal force flings the solder right out of them. You end up with poor connections or no connections and a gutless starter. If it is a 6v longhood, even a low compression all fuel will barely crank even if everything is top notch if the petcocks are closed. They don't roll fast even if the spark plugs are out! If somebody put gas or higher compression pistons in it, forget it. Petcocks MUST be open. In the winter I either use a crank or a hand start A.
clooney
02-20-2000 19:34:03
Todd, put a amp meter on the battery (+) battery post to ground and the(-) post to the starter while cranking & see what kind of losses you have in the cables & connections, If you have a measurable ammount, replace the cables & clean the connections. If its a 6v you can't afford to lose much and get it to crank good. You might try thinner oil for the winter too.
Big Buck
02-20-2000 19:13:11
Is it a 6 volt or 12 volt? Slow cranking is just the way it is with a 6 volt system.
Louie
02-20-2000 18:20:07
Sounds like it needs rebuilt.
