35 4 bolt b paint
tarzangun
05-15-2008 19:10:03
Hey there fellers;Can any one answer a question on the correct way to paint a 4 bolt B ? specifically , The radiator hoses. Do they get painted ? and do the clamps get painted ? Or do you leave them unpainted? Advise would be greatly appreciated. Thanks, Randy
DScott
05-16-2008 08:35:48
 Re: 35 4 bolt b paint in reply to tarzangun, 05-15-2008 19:10:03
third party image
I'm not sure what the official definition of Expo Quality is but I like to leave some of the items such as hoses, clamps and etc. unpainted. To my eye it shows off the detail and has a cleaner appearance. But, I am pretty sure that they did not come from the factory that way. I think they probably just hosed everything down with the paint gun and called it good. Here is a pic of my 4 Bolt B engine.
Will P
05-16-2008 13:28:44
 Re: 35 4 bolt b paint in reply to DScott, 05-16-2008 08:35:48
Looks nice, but why don't you paint the carb????
DScott
05-16-2008 18:03:56
 Re: 35 4 bolt b paint in reply to Will P, 05-16-2008 13:28:44
Well, there again I kind of like the cast look and it seems that most I have seen painted eventually stain, blister or something. They do look sharp when freshly painted green though.
RobMD
05-16-2008 13:48:07
Because paint DOESN'T like gasoline on it. Eventually, gas will 'seep' slowly under the paint and peel it off.
Common practice now is to dip the carb in acid and paint it with linseed oil.
tarzangun
05-16-2008 06:30:26
You hear about "expo quality" paint jobs. What would you expect iyt to be under that catagory? Thanks again ,Randy
Mike M
05-16-2008 04:54:29
I agree with the others. I like the different contrasts so I leave my hoses black. I also think these were painted after assembly and got green squirted on everything they could see back in the day. I am not a big fan of wire clamps so I use band type. I leave them stainless or I found some black ones that look good too.
Two-Cylinder
05-15-2008 22:36:57
i have painted about 5 unstyled B"s in the past and do not paint the hoses or the wire clamps. i personally like to see the different colors and the detail of not painting those things. i think it shows a better job even if it wasn"t factory original. i like to use the correct parts to restore things as close to original as possible but the bottom line here is you will be preserving a piece of history so as long as it isn"t going to the scrap yard, it is all good as far as i am concerned.
TIMAR
05-15-2008 19:58:44
On mine, I painted the clamps black and left the hose unpainted, but I am pretty sure JD just shot green paint oaver everything after final assembly. Just do what looks best to you.
