Help with a G
Doc Larry
05-15-2008 18:52:20
A friend has a G over in North Dakota that we'd like to bring back here to fix up so he can use. It's been sitting a long time, and outside part of the time, we think. He's tried to move it with it in neutral, but something seems to be bound up. It will move back an forth maybe 6 inches, then binds. I'm not a bad mechanic but the only JDs I've been around were a 410 backhoe and a grader back in the 70s, and the tractor is a couple hundred miles away, so I'm not much help.
Can you guys help us out? What might keep this thing from rolling freely in neutral? At this point, all we want to do is pull this up on a trailer so we can bring it home.
Thanks!
ksstang
05-16-2008 12:56:38
 Re: Help with a G in reply to Doc Larry, 05-15-2008 18:52:20
When I purchased my 49 A a few years back, I had this same exact problem. Both the brakes were froze up. I just unbolted them clear off the tractor to get it home. Then, with lots of penetrating lubricant and time, they free'd up quite nicely.
Kyle
Unruh
05-16-2008 07:49:34
How long ago was it that they tried to move it? Was there ice in the bottom of the tranny?
Doc Larry
05-17-2008 05:19:03
 Re: Help with a G in reply to Unruh, 05-16-2008 07:49:34
Not ice, this was just a week ago.
Thanks.
Mike M
05-16-2008 05:04:36
If it is the brakes ? I have freed up many by tapping on the drum, BUT I have also split some drums doing this too ! It is really best if you can unbolt them. Then there could be another problem too which may be the real reason it was let sit ?
Doc Larry
05-16-2008 03:03:20
Thanks for the help everyone.
Andy Motteberg
05-15-2008 21:19:15
I'll bet it is the brakes stuck. Remove the brake housings on each side and see if it rolls.
s.crum
05-15-2008 21:01:33
Had the same thing with my 44' A when I got it.
Had to take the brake units off (unbolt and pull out of the sides of the main case). The shoes were rusted tight in the drums.
730-LP
05-15-2008 19:01:30
Check the brakes if they were locked down when parked they could be stuck
Doc Larry
05-15-2008 19:55:07
 Re: Help with a G in reply to 730-LP, 05-15-2008 19:01:30
This has disc brakes like many of the other 40s and 50s tractors?
garytomaszewski
05-15-2008 20:18:36
 Re: Help with a G in reply to Doc Larry, 05-15-2008 19:55:07
Nope, drum brakes on each side of the platform. Tap heartily on each drum make sure that the pedals are pulled back. The clutch discs could also be stuck.
Doc Larry
05-17-2008 05:20:44
 Re: Help with a G in reply to garytomaszewski, 05-15-2008 20:18:36
How would a stuck clutch keep this from moving if the transmission is in neutral?
Thanks.
Will P
05-15-2008 20:11:52
Drum
