jd a rockers
johndeereman
05-15-2008 16:39:18
does anyone know how much to cut out of the intake rockers on a jd a to make them a ratio rocker? i can by 2.0 ones for like 300 each but i can make them cheaper than that if i know how much to take out
kendak
05-16-2008 17:48:38
 Re: jd a rockers in reply to johndeereman, 05-15-2008 16:39:18
cut them with a chop saw the width of the blade is just right...try to find & use the late "A" stamped steel rockers instead of the cast ones ...can get the part # later on if you need it...Kent
AW Puller
05-15-2008 16:50:22
You can get a set of 4 rocker arms and 2 stands for $300 total. If you cut very much out of your stock ones to shorten them, your pushrods are going to hit the cylinder head.
