2940 Brake valve
Pat McNeil
05-15-2008 12:14:05
I just finished rebuilding the brake valve on my 2940 and now the pedals will not go down. The pistons will move approx 1/4" then stop as if they are hitting something solid.It is pretty simple valve--what did I do wrong when putting it back together ?? Thanks, Pat
WTW
05-15-2008 14:21:24
 Re: 2940 Brake valve in reply to Pat McNeil, 05-15-2008 12:14:05
Pat, The check valve that is under the large screwdriver slotted plug in the bottom of brake reservoir are interfereing with the valve spool and are most likely damaged. This is very easy to do if not installed correctly. When installing them the brake valve spool has to be depressed a small amount to keep check valve stem from contacting spool shoulder/gland. If check valve assembly is installed without correct position of spool the check valve will set on top of spool and bind / get bent when tightened them down in bottom of valve housing. Once they are damaged they will bind and not seat. Valve will never trap oil to allow pressure to be applied to brakes. You can replace these check valves without removing the valve assembly from tractor, just remove the plugs above them to gain access and remove them. When installing them hold pedal just off the normal "upper" stop. If resistance is felt reposition pedal a little until valve assembly can be installed without interference with spool. Good Luck, DW
Pat McNeil
05-15-2008 22:06:20
 Re: 2940 Brake valve in reply to WTW, 05-15-2008 14:21:24
Thank you very much.
