JD850-modify to groom ski trails
Doug Spalding
02-20-2000 16:43:11
Short of adding the half-track kit, at a horrible expense, does anyone have any ideas about modifying this tractor to have better floatation on snow? I keep thinking that if the front tires were twice as wide it would work fine.The front tires sink but the rears, even loaded, don't sink in. Is there a way to put dual wheels on the front? What about widening the wheel itself by splitting the rim and adding a 6 inch band of steel in the center, then mounting a wide profile tire? Would the extra traction provided do any nasty stuff to the front drive equipment?
TIA
Doug
RonMC
02-21-2000 17:58:19
 Re: JD850-modify to groom ski trails in reply to Doug Spalding, 02-20-2000 16:43:11
Hi Doug ! Has the MC broke down ? My 770 has turfs on it, about twice as wide as the regular tires, but might be an expensive try, don't think they would float if the snow is very deep. Breaking thru of course would just be an excuse to get the crawler out.
Doug Spalding
02-22-2000 05:06:01
 Re: Re: JD850-modify to groom ski trails in reply to RonMC, 02-21-2000 17:58:19
What a memory, Ron! No, the MC is running like a top, but it's slower than molasses. It doesn't get stuck though!. I run turf tires all year, as "Mother" hates when I tear the lawn up! The 850 is fine in the snow until I slip off the edge of the packed parts of the trails. then, WHOOPS! Like I said, the rears are fine, so my theory is that if the fronts were 18" wide I could go anywhere. I'm more concerned with whether the stresses would be bad for the front end diff.
Thanks for the help.
Doug
RonMC
02-22-2000 18:59:24
 Re: Re: Re: JD850-modify to groom ski trails in reply to Doug Spalding, 02-22-2000 05:06:01
Doug, I don't think the size (diameter) will harm the diff any if you're running in snow. Are you running cleated tires now ? I would think with MFWD, the grips might be the best, as turfs may not have the gripping ability in that condition, and if you slip in, it's a tow for sure. Could take a while if you're a couple miles from the MC. My memory isn't too bad, usually find my way home from work each day, but we did have a bit of a "saga" there to get you the right GOOD parts, so it will stick with me for quite a while. Hope you're having a good year, I saved your e-mail in case I head out to visit a cousin in Nova Scotia. Am making a trip to Sask. in june to pick up a free "D", so a new project for my dotage, Ron
David*
02-20-2000 20:46:18
Might want to check into turff tires and rims, I know they are wide, should stay on top of the snow.
